Old 08-15-2010, 05:16 PM   #1
outdoor shower advice
I am planning to install a showerhead just outside my basement under my deck. My deck is about 10' above the concrete patio below. I want to run a hot and cold water line about 10' outside the basement on the underside of my deck and then come down a post to the shower head. My water heater is located immdiately on the other side of the house wall inside the basement so its very accessible. I just have a couple of questions.
1- I plan to put a shutoff on both lines inside the basement and blow out the lines before winter. Is there anything else I should consider as far as freeze protection?
2- Is PVC ok to use in an outdoor application such as this for hot and cold water or do I need to use galvanized pipe?
3- Any other advice is appreciated.
thanks
mharwell01 is offline   Reply With Quote
Old 08-15-2010, 05:28 PM   #2
Owner
LateralConcepts's Avatar
I think your best bet is PEX in an outdoor setting.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS,LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
LateralConcepts is offline   Reply With Quote
Old 08-15-2010, 07:44 PM   #3
Super Moderator
I second the PEX---Most tolerant to freezing---Make sure that it has the UV protected coating--
or plan on replacing it after a few years.
Old 08-16-2010, 12:56 AM   #4
DIY Hack
Mr Chips's Avatar
you may want to put a sillcock on each line, below the shower head ( a couple feet off the ground). This will allow you to hook a hose up should you ever need to, and will also aid in draining the lines at the end of the season, since it will be at the lowest point in the line.
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
looking for Serious advice and Help on Insulation bfan781 Building & Construction 6 05-19-2010 12:02 PM
DIY Advice Seeker - late 1970 seventies knockdown texture onegative Drywall & Plaster 1 04-22-2010 09:40 AM
Electrical Advice Caution!!! Mike Swearingen Electrical 12 03-05-2008 12:51 PM
I need advice on a flat roof Krissy Roofing 10 12-27-2007 02:55 PM
