Outdoor Faucet Repair - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-06-2011, 03:00 PM   #1
Rewards Points: 47
Outdoor faucet repair
Hi,
I'm in need of a little direction on repairing my outdoor faucet. As you will see a crack has appeared. Can someone offer suggestions on how to fix this. The downspout leads to my outdoor sprinkler system.
tate16t is offline   Reply With Quote
Old 05-06-2011, 03:13 PM   #2
Household Handyman
Rewards Points: 1,408
You will have to replace this check valve with a new one. Actually you may have to put in a "Backflow Preventer Device/BPD" to meet current codes in your area. A horizontal swing check valve IS NOT a BPD. You will need to heat, take apart, and re-sweat two joints as this is in now.
Old 05-06-2011, 11:01 PM   #3
biggles's Avatar
being an hvac tech i would wire wheel that crack flux it up and paint it with some stay brite solder first remove that cap/nut and gasket if it has one... wire brush the crack on the inside also flux it...or totally repalce it.if you do it yourself wire brush all the exsisting soldered parts makes it easier to re install wipe the joints with flux before breaking it down
Old 05-07-2011, 08:43 AM   #4
Plumb or Die!
Being a plumber, I wouldn't do that. The check valve's body has distorted from freezing or whatever, and will no longer function as it should. I would cut out the whole schmozzle. Replace that swing check with at least a dual check valve assembly. Get it inside the house if you can. Irrigation should have a connection where you can hook up compressed air for winterizing or maintenance.
plumber666 is offline   Reply With Quote
$1440+ labor only repair on 3 yr. old Goodman unit!?! JMK HVAC 23 05-06-2012 11:45 AM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 09:49 AM
Repair Compounds saggdevil Painting 3 04-25-2010 04:02 PM
What do you guys think of this roof repair job? darsunt Roofing/Siding 7 08-21-2009 09:43 PM
Fire repair detroitguy66 Building & Construction 3 08-20-2008 06:49 AM
