Outdoor Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-03-2015, 12:29 PM   #1
Rewards Points: 1,050
Outdoor faucet
What is the recommended pipe size to feed an outdoor faucet: 1/2” or 3/4”?
french_guy is offline   Reply With Quote
Old 06-03-2015, 12:30 PM   #2
Rewards Points: 474
1/2" is common
BrowneBearLLC is offline   Reply With Quote
The Following User Says Thank You to BrowneBearLLC For This Useful Post:
oh'mike (06-04-2015)
Old 06-03-2015, 12:30 PM   #3
Rewards Points: 2,032
Attached to the house 1/2 inch is the usual.
Old 06-03-2015, 12:56 PM   #4
My current outdoor faucet is in bad shape, so I will have to replace it
In my basement, I have a 3/4" copper piper going from the water meter to the other side where the line goes out for the faucet. It’s about 8 yards
But the last 3 feet are with 1/2" pipe
Since I will redo it, should I keep everything at 3/4”, or should I keep that reduction 3/4 to 1/2 ?
What do you think about those silcock :
http://www.homedepot.com/p/Everbilt-1-2-in-x-10-in-Brass-MPT-x-MHT-Anti-Siphon-Sillcock-VFFASPC17EB/205811968
And apparently, they are all in 1/2” size….
Old 06-03-2015, 02:33 PM   #5
Rewards Points: 1,666
Being the hydrant is 1/2 I wouldn't bother changing that last 3 ft. to 3/4 then back to 1/2. If you were running a couple hundred feet and needed all the flow you could get then probably make the change but not in your situation.
SeniorSitizen is offline   Reply With Quote
Old 06-04-2015, 07:18 AM   #6
Lord of Slums
Rewards Points: 1,974
everbilt- should of called them ever replacing
mj12 is offline   Reply With Quote
Old 06-04-2015, 09:19 AM   #7
Are you saying they are crap? Not worth the price (~$25)?
Old 06-04-2015, 12:01 PM   #8
Rewards Points: 3,130
I think Everbilt is a Home Depot house brand. I have no personal experience with their faucets, but most everything else I've tried is Chinese junk.
Old 07-05-2015, 05:27 PM   #9
OK, it's installed....
There are 2 holes on the stem (we can see one of them on the picture)....When the valve is opened, some water is coming out of the holes !!!
Sounds weird to me......is it something to do with the vacuum breaker?
Or the unit is defective?
Old 07-05-2015, 05:35 PM   #10
Rewards Points: 318
Try tightening that packing nut down right behind the handle, that should do it. If not, I'd take it back and get another one.
jmon is offline   Reply With Quote
Old 07-05-2015, 05:43 PM   #11
The packing nut was loose, so I tightened it up....
If I have to return the whole unit....grrrr, such a pain. I installed a ball valve at the end of the faucet, where access is somehow limited. It was a pain to tighten it up, and it will be a pain to remove......
Should I try to take the stem apart first?
Old 07-05-2015, 06:35 PM   #12
Rewards Points: 318
No need to remove stem, just tighten the packing nut. You said packing nut was loose and you tightened it. Is it still leaking? Did it help any?
If you soldered this hose bib to the copper pipe inside, did you remove the stem first before soldering? If not, the washer may be damaged and you will have to replace it.
Old 07-05-2015, 06:42 PM   #13
There was a leak right behind/around the packing nut, this is how I noticed it was loose
I tightened it up, so no more leak in the area
But I still have water coming out of those 2 holes, after 1 or 2 sec once I open the valve
I didn't sweat anything. Only installed a ball valve (1/2" NPT Female)
The Following User Says Thank You to french_guy For This Useful Post:
jmon (07-05-2015)
Old 07-05-2015, 07:14 PM   #14
Rewards Points: 318
That's strange. I would shut off the water and remove the stem, check all washers and o rings, make sure everything is seated properly and not kinked, reinstall it and try again.
If that doesn't help, I would take it back and get another one. A brand new frost free hose bib shouldn't be leaking anywhere. May have a manufacturer defect in it.
Old 07-05-2015, 07:55 PM   #15
Will do that....
By the way, what is the purpose of those 2 holes on the stem?
