Outdoor Electrical Outlet And Propane Regulator - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-17-2012, 10:06 AM   #1
Rewards Points: 264
Outdoor Electrical Outlet and Propane Regulator
Is there a mandatory separation distance from an outdoor electrical outlet and a propane regulator with manifold?
I've found some separation requirements to fireplace vents, property lines, ac units, and crawlspace doors. What about electrical?
I'm planning to have a propane line ran to the house with a manifold for multiple devices. Spot selected to mount the manifold is near an outdoor electrical outlet with weather proof cover.
Earnie is offline   Reply With Quote
Old 07-17-2012, 09:34 PM   #2
The clearances from relief discharge are:
-3' from building openings, appliance vent outlets, and moisture exhaust ducts
-10' from mechanic air intakes, appliance air intakes and sources of ignition (an electrical outlet is a source of ignition)
These are the clearances under the Canadian natural gas and propane installation code. Yours may be different. Your installer should know. If they don't, get a new installer.
hvac benny is offline   Reply With Quote
Old 07-18-2012, 08:46 AM   #3
Rewards Points: 264
Thanks Benny.
I wish it were that easy to find a competent installer. That's why I'm asking.
The previous tank I had installed, by a nationally known propane supplier, was located next to the crawlspace door; there was no three foot separation. The drivers who filled the tank never mentioned it either.
need help with propane burner gas valves rtockstein HVAC 14 04-05-2012 04:02 PM
Generator outlet and propane tank dougp23 Electrical 6 10-25-2011 02:32 AM
3 wire 50 amp outlet with 4 wire cable dlyon2 Electrical 9 10-09-2011 07:32 AM
Remove fitting from propane line btrevillyan Plumbing 2 06-02-2009 10:55 PM
Outlet proximity to gas wall heater? Wavelength1550 Electrical 1 11-12-2008 10:50 PM
