Outdoor Drainage Pit For Indoor Sump Pump Discharge - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-14-2010, 06:37 PM   #1
Outdoor drainage pit for indoor sump pump discharge
Hi All:
I have an indoor submersible in a sump pit. It discharges through the basement wall to the outdoors and the drainage pipe runs down hill under the earth and the pipe exits at grade level after running 40 feet or so. When this system was installed there was no issue, but since that time the previous owner severed the existing lot into two lots, mine and the new neighbours. Unforunately the drainage pipe ends right on the lot line between the 2 properties. My plan is to cut the pipe back 4 or 5 feet and dig a pit about 3-4 feet cubed and fill it with gravel 5/8" or 3" minus. This way I am hoping the water won't pool on either lot, nor will reeds grow where the water empties onto the lawn.. Will this work? Any recommendations on size of stone for pit or anything else. Appreciate any advice given.
D Paul is offline   Reply With Quote
Old 06-15-2010, 06:08 AM   #2
There is no way for us to determine if a drywell will work. Soil conditions, slope, etc, are all need to know conditions.
Sump Pump Questions henlij Plumbing 22 03-16-2015 10:00 PM
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 12:03 PM
Well Pump Problems dannyjoe Plumbing 6 10-01-2009 06:10 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
Sump Pump Discharge in MN livinginthepark Plumbing 5 11-12-2008 12:04 PM
