Out Of Round PVC - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-22-2012, 06:31 PM   #1
Rewards Points: 29
Out Of Round PVC
I need some advice.
I have a buried pool return line that is 1 1/2 inch PVC. I am not sure if it always was, or became oval over 10 or so years, but the union will no longer fit into it.
I need to connect to it somehow.
What do you recommend to round it?
Ideas I have involve a big clamp, or a heat gun/hairdryer, but with the latter I am concerned about the joint not holding
kaalapurushha is offline   Reply With Quote
Old 05-22-2012, 07:49 PM   #2
Rewards Points: 636
cut out pipe and replace is the best fix
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
The Following User Says Thank You to jaydevries For This Useful Post:
COLDIRON (05-23-2012)
Old 05-22-2012, 08:36 PM   #3
Take a C-clamp and put it on the long axis and crank it down and let it set for a couple of days? A heat gun might speed up the process.
broox is offline   Reply With Quote
Old 05-22-2012, 09:40 PM   #4
Rewards Points: 582
Originally Posted by kaalapurushha View Post
I need some advice.
cut out and replace it best sure repair.....you could try heating ...but I don't think it worth the time or effort....imo..
The Following 2 Users Say Thank You to ben's plumbing For This Useful Post:
COLDIRON (05-23-2012), plummen (05-23-2012)
Old 05-23-2012, 06:48 AM   #5
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
If all else fails you could try using a mission coupling to try and make it work
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
The Following User Says Thank You to plummen For This Useful Post:
ben's plumbing (05-23-2012)
Old 05-23-2012, 07:26 AM   #6
Rewards Points: 29
I would definitely cut and replace if I could. There is about 10" sticking out of the ground, and all of it is oval. The rest goes about 50 ft under dirt, mulch, and concrete to the pool jets!
I'll give the C-Clamp a try for a few nights.
Is there a pressure rating on a mission clamp on 1 1/2 PVC? The junction is after the filter, and the elevation above the return jets, so its technically 'lower' pressure.
Old 05-23-2012, 09:27 AM   #7
MarginallyQualified
Rewards Points: 2,464
You can. You may not *want* to... but I assure you that you can
Dirt and mulch are easy digging. Start there.
If you need to break up concrete to get to good round pipe... do so.
The Following User Says Thank You to TarheelTerp For This Useful Post:
Installing Light on Round Junction Service Box MegR Electrical 7 07-07-2013 08:31 PM
Transition From Square To Round rjordan393 HVAC 2 07-29-2011 09:48 AM
Clipped Head v. Full Round Head Nails RickT Carpentry 10 11-18-2010 09:00 AM
Can I split airflow from a 640cfm hood, 10" round to two 3.25x14 ducts ductdawgz HVAC 10 03-25-2010 03:16 PM
quarter round + door frame= headache fenceman Flooring 3 02-15-2009 02:28 PM
