Osmosis Flow. - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-08-2013, 11:12 AM   #1
Osmosis flow.
I'm having a water flow problem with my RO system. Water flow was bad last Month so I changed the two filters and membrane which temporarily fixed the problem. The pressure in my tank is 10 psi empty and when I disconnect the tank from the system and open the valve water flows really well. I knows the spigot works because i took out the RO system and put in a 3 filter water purification system which the water runs fine. I just cannot figure out what the problem is. Any ideas?
bman3940 is offline   Reply With Quote
Old 01-08-2013, 10:52 PM   #2
Registered User
Rewards Points: 5,466
My Watts instruction manual says 7# with empty tank, if same brand... check lines for kinks, make certain pump operates, ensure valves are open fully- turning counter-clockwise with angle stop or water line valve, 5-7# optimum air pressure.
Gary
Old 01-09-2013, 01:18 PM   #3
Water Treatment
Rewards Points: 850
What is the incoming water line pressure for the ro system?
It could be that you will need a buster pump for the ro system.
Akpsdvan is offline   Reply With Quote
Old 01-23-2013, 12:01 PM   #4
Thanks for the replies! Turns out one of the filters I replaced last month was bad. When i swapped the pre and post filters water was flowing just fine! It was that simple. The post filter was bad.
flow control valves jmon HVAC 9 12-12-2012 10:53 AM
I thought I understood plumbing, private well flow rate question ChrisDIY Plumbing 22 07-25-2011 10:14 AM
Moving HVAC ducts/registers & reverse flow ?'s cbrc5eric HVAC 3 06-09-2010 05:05 AM
Hot water faucet pipe thumps then flow slows down. DIY-Indy Plumbing 9 07-15-2009 11:09 PM
very low shower head flow rickard681 Plumbing 7 10-08-2008 06:43 AM
