-   -   Osmosis flow. (http://www.diychatroom.com/f7/osmosis-flow-168574/)
bman3940 01-08-2013 11:12 AM
Osmosis flow.
I'm having a water flow problem with my RO system. Water flow was bad last Month so I changed the two filters and membrane which temporarily fixed the problem. The pressure in my tank is 10 psi empty and when I disconnect the tank from the system and open the valve water flows really well. I knows the spigot works because i took out the RO system and put in a 3 filter water purification system which the water runs fine. I just cannot figure out what the problem is. Any ideas?
Gary in WA 01-08-2013 10:52 PM
My Watts instruction manual says 7# with empty tank, if same brand... check lines for kinks, make certain pump operates, ensure valves are open fully- turning counter-clockwise with angle stop or water line valve, 5-7# optimum air pressure.
Gary
Akpsdvan 01-09-2013 01:18 PM
What is the incoming water line pressure for the ro system?
It could be that you will need a buster pump for the ro system.
bman3940 01-23-2013 12:01 PM
Thanks for the replies! Turns out one of the filters I replaced last month was bad. When i swapped the pre and post filters water was flowing just fine! It was that simple. The post filter was bad.
