Original Sink In Basement, Made Of Concrete Or Cast Iron? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-22-2014, 10:27 AM   #1
Rewards Points: 87
Original sink in basement, made of concrete or cast iron?
I have a basement tub sink with two sides that when I recently turned on after 15 years, it was leaking from the base.
The sink I believe is made of cast iron or concrete. I saw a crack running down the front of it.
I was wondering if there is an epoxy or something I can run over it, to stop the crack from leaking?
Any suggestions would be helpful.
Trish
Ttd0715 is offline   Reply With Quote
Old 01-22-2014, 03:34 PM   #2
Rewards Points: 13,296
Got a picture?
Old 01-22-2014, 09:01 PM   #3
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Trish
I still see a lot of those old 2 compartment wash sinks, im guessing its probably concrete.
Depending on how bad it is I suppose you could v out the crack with a grinder and epoxy up the crack.
If you could find the end of the crack you could hammer drill a small hole there first to stop the crack before filling it in.
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
The Following 2 Users Say Thank You to plummen For This Useful Post:
ben's plumbing (01-23-2014), joecaption (01-22-2014)
Old 01-22-2014, 09:09 PM   #4
Or just buy a new one with no leaks that will be good to go for another 20 years.
http://www.homedepot.com/p/MUSTEE-18...-12C/202041452
Old 01-22-2014, 09:19 PM   #5
plummen's Avatar
Ive had to lug a few of those big pigs out of basements over the years, I prefer to beat them into submision with a sledgemammer first.
Old 01-22-2014, 09:22 PM   #6
Small pieces, 5, gal. bucket, way to go.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
ben's plumbing (01-23-2014), plummen (01-22-2014)
Old 01-23-2014, 09:21 AM   #7
Rewards Points: 87
Hi Guys,
I'm guessing it's probably concrete as well. I think I'm going to go the route of the hammer drill and epoxy first. I'm new to the term "hammer drill", but if I was to guess, it would be taking a nail with a hammer and
making a small hole at the bottom of the crack??
Then use the epoxy on the crack, after I've stopped the crack from growing. This is a sink that hardly ever gets turned on, so I don't want to break it up, and have to dispose of it.
Please advise if this is what hammer drilling is?
Thanks for all of your lifesaving tips!
TTD
Old 01-23-2014, 09:51 AM   #8
DIY staff
Rewards Points: 7,174
A hammer drill is an electric drill that 'hammers' as it spins---
That thing will cost as much as a new sink--just clean out the crack and epoxy it---
The old concrete sinks start to fall apart when they get old---don't spend much trying to save that---the drain will fail next--so it's just throwing good money after bad at this point.
joecaption (01-23-2014)
Old 01-23-2014, 11:46 AM   #9
Owner
LateralConcepts's Avatar
Before you go chiseling, hammering, and sealing with epoxy, I'd suggest doing a little research. Some of those old concrete wash basins can be worth some money to collectors. Replace it with a new plastic one and be done with it. Put the old one on eBay or Craigslist.
http://www.ebay.com/itm/Old-Vintage-...-/200922582456
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 01-23-2014, 12:35 PM   #10
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 736
Unbelievable.
There were days when you payed someone to remove your junk. Now you get your junk removed and get payed to boot.
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is online now   Reply With Quote
Old 01-23-2014, 06:15 PM   #11
Rewards Points: 582
concrete...bang bang bang..went the hammer its time to beat it up and bury it...... ben sr
The Following 2 Users Say Thank You to ben's plumbing For This Useful Post:
oh'mike (01-23-2014), plummen (01-23-2014)
Drilling into concrete foundation to remove cast iron drain pipe Remmy Plumbing 2 12-09-2012 06:33 PM
Overhead Cast Iron DWV pipe replacement in basement bgolden1 Plumbing 4 04-05-2012 07:20 PM
Concrete: Top Cast vs. Acid Stain/Wash sportinwla Landscaping & Lawn Care 0 07-09-2010 03:15 PM
Replacement sink with cast iron model Mike in Arkansas Plumbing 5 02-14-2010 09:12 AM
Cast Iron Sink cellophane Plumbing 4 12-02-2009 02:36 PM
