Original Shutoff Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-07-2010, 02:02 PM   #1
Rewards Points: 278
original shutoff valve
My bathroom has a single handle faucet that I want to change out,
inside the sink cabinet is 2 shutoff valves coming out to 3/8 outlet (i think compression type) pointing up. It is plumbed with small hard copper lines from the valve up to the faucet.
The faucet clamps by 2 toggle bolt angle anchors. I plan to loosen these first. Then will there be any difficulty undoing the compression fitting from the shut off valves? everything look slightly oxidized
The new faucet will use a 3/8" inlet to 1/2" outlet teflon lined, braided hose up to the faucet.
DIYGST is offline   Reply With Quote
Old 12-07-2010, 03:12 PM   #2
Rewards Points: 150
You have to turn the water off first, then you loosen the supply tubes THEN you can take the faucet off
braindead is offline   Reply With Quote
Old 12-07-2010, 03:18 PM   #3
Rewards Points: 278
Is a flare nut wrench a good idea if I have one? vs adjustables
Old 12-07-2010, 03:26 PM   #4
Rewards Points: 459
You may be able to use a little heat to loosen them up if they give you a hard time.
Try not to use a crescent wrench on the brass, tubing wrenches being ideal; or in this case, since you're scrapping the tube anyway, cut the tube and use a 6 point box wrench or socket.
Nick DIY is offline   Reply With Quote
Gas shutoff for fireplace WishIWasAPlumbr Plumbing 13 03-07-2010 10:36 PM
Replacing/Fixing leaky shutoff valve under sink JeffWireman Plumbing 4 02-15-2010 10:30 PM
Looking for bathroom sink shutoff valve solution tigereye Plumbing 2 01-23-2010 09:36 PM
Can't reinstall shower valve properly ptoneil Plumbing 3 04-10-2008 10:05 PM
Bathroom Sink Shutoff Valve, Supply Lines, Removing CathrynH Plumbing 9 01-10-2008 12:28 AM
