Options For Supporting This Copper Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-13-2009, 05:36 PM   #1
Options for supporting this copper pipe
I want to make this ceiling in basement level with the floor joists. Can I use plumbers tape to support the pipes?
Thanks,
Bryan
bkeech is offline   Reply With Quote
Old 01-13-2009, 05:59 PM   #2
I wouldn't use any kind of tape, If it is 1" copper they sell nail clips at plumbing supply stores or maybe even Lowes, They sell them with nails already included, there easy fast and cheap.
zosoplumber is offline   Reply With Quote
Old 01-13-2009, 06:04 PM   #3
Rewards Points: 1,578
Make sure you don't change the pitch of any drain pipes when trying to get them above the joist level or your drains will not be drains.
bob22 is offline   Reply With Quote
Old 01-13-2009, 06:19 PM   #4
Thank you both. For the drain pipe I am going to nail in trimmers and blocks to support it. But the copper supply pipe is level with the bottom of the joists. I want to remove those spans of 2x4s.
Old 01-13-2009, 07:34 PM   #5
Rewards Points: 20
You can run some nailers between the joists above the pipe and use one of the hangers in this link http://www.warwickhanger.com/catalog...copper-tubing/
ponch37300 is online now   Reply With Quote
Old 01-13-2009, 09:42 PM   #6
Rewards Points: 562
If your drywalling this wall and ceiling,,,you need a nailer over at the top of the wall to support the ceiling drywall at the corner,,,where the yellow wire is!!
4just1don is offline   Reply With Quote
Old 01-14-2009, 04:07 PM   #7
Don,
Should I run a 2x4 parallel to the wall there, or can I nail in blocking perpendicular to the wall (nailed to the wall and the joist there)?
Thanks,
Bryan
Old 01-14-2009, 04:33 PM   #8
Rewards Points: 20
You should run a 2x4 parrallel to the wall. You just set it half way on top of the top plate of the wall and nail to the top plate. That will leave you 1 3/4" or so all the way along the wall to attach the drywall to.
Old 01-15-2009, 04:53 PM   #9
yes you can plumber tape, it is band iron, or (Strapping) you can use it on pvc, must turn it on the pipe once then tie it to the joist every 4 feet
metx is offline   Reply With Quote
Old 01-15-2009, 07:54 PM   #10
Oh, I use strapping all the time especially for PVC, never heard it called "tape". Learn something new everyday!
can you bury copper pipe ? amakarevic Plumbing 12 08-05-2009 06:25 PM
nicked copper pipe analogmusicman Plumbing 3 07-28-2008 08:54 PM
misfits b/ween copper supply pipe and fittings amakarevic Plumbing 8 06-10-2008 08:39 PM
copper strap around copper pipe? analogmusicman Plumbing 3 06-04-2008 10:55 AM
Can I Extend the 3/4" Copper Pipe? froddan Plumbing 2 07-23-2007 04:03 PM
