Opinion Needed About Changing Kitchen Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-31-2009, 03:10 PM   #1
Opinion needed about changing kitchen faucet
So I'm in a bit of a predicament and I need an opinion. I'm attaching a photo of the plumbing under my sink and I'm wondering what is the best way to proceed with the installation of a new faucet. You'll notice there is no valve to switch off the hot/cold water and it is simply connected with copper piping and some soldering. I am wondering if I should install valves myself or if I should just melt the solder, remove the copper piping, and fit the new hot/cold attachments and solder them in place. Thanks for the help.
chris_p is offline   Reply With Quote
Old 01-31-2009, 03:18 PM   #2
If they can't be easily shut off I would add valves
Old 01-31-2009, 05:20 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 590
Ayuh,...
I'd cut them off up on the 3/8" tubing,...
Add a couple of compression fitting stops,+ then on to the faucets...
Bondo is online now   Reply With Quote
Old 01-31-2009, 05:27 PM   #4
Carpenter
DecksEtc's Avatar
You're going to the trouble of removing the old tap and pipes so you might as well do it right and add shutoff valves while you're at it.
Terry
DECKS Etc.
GardenStructure.com
DecksEtc is offline   Reply With Quote
Old 01-31-2009, 05:46 PM   #5
Ya I think that would be the easiest way. I'll have to shut the water off to the whole house because there are no valves under the sink but I'm sure everything will go fine. Thanks.
Old 01-31-2009, 05:59 PM   #6
Rewards Points: 2,906
While you're at it, replace that stupid Emco valve with the blue handle.
Those things don't have a packing nut. Instead, they use an O-ring to prevent water from seeping past the stem. The problem is that after a while, you can't open or close those valves without water leaking past that O-ring.
If you're going to be shutting off the water to do some plumbing, you should replace that Emco valve with a ball valve too. And, get a ball valve with a packing nut. Some companies are making ball valves without packing nuts, and I think that dumb too.
Obviously, use a heat shield when soldering to prevent messing up the interior of your cabinets.
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
Old 01-31-2009, 07:54 PM   #7
Thanks for the advice. I'm just wondering if it would just be easier to install a compression valve instead of a ball valve to avoid soldering. This is my first plumbing project so I'm a bit of newbie in this area.
Old 02-01-2009, 05:03 PM   #8
So I've installed everything and now I'm having a problem with low hot water pressure. The cold water seem to be ok, but neither is as strong as before the installation. I installed two compression valves and I used flexible tubing instead of the 3/8 inch copper piping that was in place before. I don't think the faucet is faulty because it is brand new. Any ideas what could be causing the low hot water pressure? The flexible tubing isn't perfectly straight from the compression valve to the faucet valves, it curves a little bit because it was too long. Would this make a difference either? Thanks.
Old 02-01-2009, 05:59 PM   #9
Send a message via MSN to Simply Sal
In your picture, the braided line from the taps on the left side looks a bit pinched... check that.. also remove your aerator and see if you have some build up in there, simple but amazing how it can change the water pressure.
Simply Sal is offline   Reply With Quote
Old 02-01-2009, 06:00 PM   #10
Carpenter
DecksEtc's Avatar
The "curve" shouldn't be an issue but it does look like they're kinked a bit. Maybe they're fine but it's a little hard to tell from the photo.
There could be a problem with the fittings - kind of obvious but are you 100% sure they valves are open all the way?
Also, there could be a problem with the taps. Just because they're new doesn't mean they're okay.
Good luck.
Terry
DECKS Etc.
GardenStructure.com
Old 02-01-2009, 09:10 PM   #11
I disconnected the hot and cold lines from each compression valve because I wanted to test each valve. When I turned each valve on separately (and drained them into a bucket), there was high water pressure coming out of each hose, so that isolates the problem to the tap. I checked the aerator and it was clean, and I also tried to isolate the flow to a part of the tap but I couldn't find anything. Do you think I have a lemon for a tap and should I return it? Thanks.
Old 02-01-2009, 11:39 PM   #12
When switching from a standard kitchen sink faucet to a pull-out spout faucet you will notice a difference in the volume/pressure.
This type of faucet has a integral backflow preventer or two but I think the big difference is in the softer feel of the water as it leaves the spout. If you remove the aerator on the spout head you will find more than you're average of screens. I believe the combination of these devices cause the preceived poor performance of the new faucet. This is most noticable in houses with relativley low water pressure.
It's also possible that the in-line check valve on the spout hose is clogged.
kitsapjack is offline   Reply With Quote
No hot water pressure at kitchen faucet tracker883 Plumbing 2 12-30-2008 06:10 AM
Low hot water pressure on kitchen faucet Ultrarunner2017 Plumbing 7 12-19-2008 10:49 AM
Can I install a kitchen faucet on Utility sink/tub?? TDRohn Plumbing 4 09-17-2008 01:13 PM
Trouble removing old kitchen faucet vikinghelmet Plumbing 1 08-18-2008 03:02 PM
Question about a kitchen faucet skwpt Plumbing 10 10-11-2007 07:54 PM
