Opening WH Drain Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-07-2012, 08:02 PM   #1
Rewards Points: 18
Just don't want to cause a problem.
Plastic water heater drain valve - the kind with the plastic knob and the screw driver slot.
I'm plenty familiar with opening the plastic knob type but on these do you turn the knob and screwdriver slot...?
We Fix Houses is offline   Reply With Quote
pressure relief valve is leaking on boiler wlmpdiycr HVAC 65 10-26-2011 06:00 PM
valve retrieval in a drain houston81 Plumbing 1 07-07-2010 05:33 PM
Air Compressor Drain Valve Red Truck Tools 3 02-11-2010 08:36 AM
Water heater drain valve leak Fletcher33584 Plumbing 3 02-28-2006 08:07 PM
