Open Sewer Pipe Under Sink Cabinet - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-02-2011, 09:05 PM   #1
Open Sewer pipe under sink cabinet
I was thawing out frozen cold water pipe. Looked under the built in vanity, and found an open sewer pipe coming out of concrete slab. Looked like it was left over from construction, but causing moisture and mold under the vanity. Looked like they tried to stop it up with old spray foam material. I want to plug this off and replace all wood. I do not think it was an old vent stack attempt. Any ideas out there as to what was/is up with this open sewer pipe coming up under a vanity and going nowhere?
NoName is offline   Reply With Quote
Old 02-03-2011, 12:43 AM   #2
Does it smell like a sewer? Can you hear water running threw it with the kitchen sink? Do not use the sink above you. If you can hear water in it then you know it is still hooked up to the sewer system.
Can you cut it and cap it?
proremodel is offline   Reply With Quote
Old 02-03-2011, 08:39 AM   #3
Not so new
12penny's Avatar
Rewards Points: 520
...old floor drain maybe. Diagnose as pro recommended.
12penny is offline   Reply With Quote
Old 02-03-2011, 09:19 AM   #4
Owner
LateralConcepts's Avatar
Post a picture
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 02-03-2011, 09:20 AM   #5
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 692
Could it have been a clean-out, that was not properly capped? How big is it (diameter)?
hyunelan2 is online now   Reply With Quote
Tap 2" Drain Pipe into 4" PVC Main Sewer Drain Pipe brmatthews Plumbing 3 12-20-2010 07:49 PM
Is yellow polyethelene or polyphenol gas pipe now the preferred gas conduit? MarkSilber Plumbing 1 09-18-2010 12:10 PM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 06:38 AM
Drain Pipe about 20 Inches to the right of Vanity Sink mark2741 Plumbing 2 12-16-2009 10:32 AM
Sewer pipe under concrete driveway marejw Plumbing 7 12-22-2007 04:19 PM
