Open Cell Foam Contact With Per Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-01-2012, 07:56 AM   #1
open cell foam contact with per pipe
Can PEX pipes be sprayed with open cell foams or does it degrade the pipes?
dafudd is offline   Reply With Quote
Old 04-01-2012, 12:34 PM   #2
Rewards Points: 13,960
Not going to hurt the tubing but why are you doing it?
I can see if your just doing some air blocking where it's run through a hole.
If your talking about spraying the whole length, why not just use foam pipe insulation, far less expencive and less messy.
Old 04-01-2012, 04:45 PM   #3
Remodeling Contractor
it can be used and will not deteriorate the pipe.
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
Photo cell for dry contact closure rjniles Electrical 1 11-16-2010 01:23 PM
Is yellow polyethelene or polyphenol gas pipe now the preferred gas conduit? MarkSilber Plumbing 1 09-18-2010 12:10 PM
closed cell vs open cell foam insulation amonalisa Building & Construction 1 11-06-2008 09:39 PM
Q: Closed Cell Foam Thinckness stangboy68 Building & Construction 10 12-07-2007 10:30 PM
