Ooh Ooh That Smell! - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-14-2012, 06:59 PM   #1
Question
ooh ooh that smell!
Hello helpful people.
I have another issue:
Not sure if it is related to the clogged sink or not, but
When it is windy outside, I sometimes get a disgusting and lethal backup of septic gasses that somehow backup into my main level bathroom.
Other times, I smell it when I run the washer, or shower on the second floor.
It always seems to happen when I am planning on having a gathering.
Not the best time for it to happen.
Thanks for any advice ( other than to move)
turion is offline   Reply With Quote
Old 03-14-2012, 07:13 PM   #2
Rewards Points: 13,750
No one here is going to know how far above your roof the vents are or there locations. If there not above the roof enough or there blocked by a dormer or wall then the passing air across the top of them may not be enought to draw up the gas until it builds up.
Old 03-14-2012, 07:15 PM   #3
they go about 2 ft above the roof, and are not obstructed by anything
Old 03-14-2012, 10:36 PM   #4
Master Plumber
Javiles's Avatar
Rewards Points: 996
Pick up some draft diverters for the vent stacks AKA vent filters they may help. common problem. Look on line, you'll need the pipe size for the vents.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 03-15-2012, 05:10 AM   #5
Happy to help
Lighting Retro's Avatar
I'm kind of curious if it's possible you don't have a P trap at a fixture and it's allowing gases to escape inside the home. I suppose that is a possibility.
Lighting Retro is offline   Reply With Quote
Smell coming from all floor registers. John_W HVAC 10 08-07-2015 06:42 PM
Bad smell in crawl space. John_W General DIY Discussions 34 06-03-2014 12:57 PM
Smell when boiler runs? dave12345 HVAC 13 11-11-2013 08:08 AM
mice smell past or present? Wiscbldr Pest Control 3 07-13-2011 12:43 PM
Sump pump smell - not sewer Thunderknight Plumbing 3 11-23-2008 08:37 PM
