Only Hot Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-12-2012, 09:31 PM   #1
only hot water
installed a new shower valve today and now only hot water comes out of all faucets on both cold and hot side. would a bad cartrige cause hot water to go to all faucets.
johnny boy is offline   Reply With Quote
Old 03-12-2012, 09:51 PM   #2
Rewards Points: 582
seems like problem started by installing new shower faucet....clean cartridge if you can ..or just replace it....to answer your question yes its possible..
The Following User Says Thank You to ben's plumbing For This Useful Post:
jaydevries (03-12-2012)
Old 03-13-2012, 06:42 AM   #3
DIY staff
Rewards Points: 7,174
If you have capped stub outs---and the valve is in the open position--you will get 'cross over'
If it's a Delta with a test plug--no cartridge installed yet--you will get 'cross over'
More details,please.
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
Well Water snuggles2010 Plumbing 3 04-13-2010 01:36 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
