-   -   Only hot or cold water (http://www.diychatroom.com/f7/only-hot-cold-water-84402/)
DiyPadawan 10-19-2010 11:38 PM
I recently had a new gas water heater (not tankless) installed in my home. Since then I have no warm water in my kitchen. The kitchen has a single handle faucet while all others in the home have the two handle style. When I turn the faucet on in the kitchen and put it in the middle I only get cold water. I move the handle to almost full left and still no warm water. Its not until the handle is at the full left position that I get hot water. It goes from ice cold to steaming hot, no middle ground.
Now in the rest of the house I can make warm water, but its not the same as before I got the new heater. In one of the showers, for instance, I turn the hot water on and its as expected. When I go to make usable warm water I have to turn the cold handle just slightly or the water will become too cold. The water pressure seems the same in both cold and hot sides.
One thing that was changed during the instal of the new heater is that the heater has been moved from inside the home to outside in a closet. The move was basically from one side of a wall to the other, but about 6 feet of line was aded to reach the top of the heater. I'm not sure if this is a factor, but worth mentioning. Any help would be greatly appreciated!
DiyPadawan 10-19-2010 11:41 PM
I'll also mention that our home has very low water pressure, about 30 lbs.
nap 10-20-2010 12:55 AM
the water pressure surely isn't helping anything but do you have any idea what the temp setting was on the old heater and what it is in the new one?
DiyPadawan 10-20-2010 01:29 PM
The temp doesn't seem to make any difference. I've changed it from just above warm to all the way hot and it does the same thing.
nap 10-20-2010 03:37 PM
it sounds like there may be a restriction in the hot water line. That could be before or after the heater.
is there any discernible difference in the hot water pressure since the new heater?
kenmac 10-20-2010 03:39 PM
Probably trash in the fixture valve. You'll have to take it apart & clean it out. It never fails when someone replaces water lines or water heater. Trash comes loose & makes it's way to 1 or all of the valves
DiyPadawan 10-20-2010 08:03 PM
Yes, we have noticed a drop in hot water pressure since the install.
DiyPadawan 10-20-2010 08:06 PM
Sounds very possible. We are on a well here and our old heater was clogged with all sorts of crap. Since we moved in we had a whole house filter/ softener installed and now a new heater. I bet you're right that some of the trash that had built up over the years came out. I'll check that out, thanks!
kenmac 10-20-2010 08:13 PM
Just an FYI. trash could make it's way to other fixtures until it's flushed out or makes it's way out of the water lines
