One Toilet Bolt Is Missing And Water Is Leaking Out From Bottom Of Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-07-2012, 10:26 AM   #1
one toilet bolt is missing and water is leaking out from bottom of toilet
One of our toilets has been secured by only one bolt for quite some time ,but now the toilet is loose and it is leaking around the bottom of the toilet. The hole in the terrazzo that held the other bolt is worn away and will not hold a bolt. I know I need to obviously remove the toilet, but is there any way to fix this without having to drill a new hole for the second bolt?
Thanks! Don
don1949 is offline   Reply With Quote
Old 05-07-2012, 10:38 AM   #2
Rewards Points: 13,450
No way to know without removing the toilet.
Toilet bolts are never just attach to the tile if that what your thinking.
There installed in the flange or with dowel bolts (I think that's the name) screwed into the subfloor.
This should have been fixed a long time ago. I'd be looking for subflooring rot if it's been leaking that long.
Septic tank missing T and badly angled main line? denemante Plumbing 3 11-22-2011 09:29 AM
No hot water at any faucet, water heater working fine rivercliff Plumbing 5 10-27-2011 09:47 AM
Dishwasher line to disposal: water in bottom of DW smawgunner Appliances 7 05-14-2011 03:37 PM
Water leaking from below new toilet C_J_GO Plumbing 12 09-27-2009 07:49 PM
