One Sink Stopped Working - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-19-2011, 10:35 AM   #1
My bathroom vanity has two sinks. One sink operates properly- (faucet turns water on and off). Second sink doesn't work. No water. I removed the faucet and supply lines. Both were in working order. I opened both water supply valves with supply lines and faucet removed and no water is coming out. What's wrong?
Daniel L is offline   Reply With Quote
Old 10-19-2011, 09:45 PM   #2
Rewards Points: 582
sounds like the faucet areator where water comes out is pluged....remove and turn on water or water to that sink has shut off valves
Old 10-20-2011, 08:25 AM   #3
I had previously done that, but thank you for the suggestion.
Old 10-20-2011, 09:07 AM   #4
Rewards Points: 150
I would just replace the valves..
josall is offline   Reply With Quote
Old 10-20-2011, 10:12 AM   #5
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Have you recently operated the shutoff valves? Sometimes operating them causes the washer inside to come loose, and when you open it back up, they block the flow of water.
Shutoff the water to the entire house so that you can pull them apart and try to work on them. It may be necessary to replace the valves. Sometimes you can leave the valve body there and just replace the guts if you can find the same brand.
Journeyman Plumber
All switches/lights and outlets in 1 room stopped working am2011 Electrical 6 12-24-2011 10:06 AM
Heat Pump Fan Has Stopped Working TurboSteve HVAC 2 12-15-2010 01:40 PM
Basement Outlet by sump pump stopped working crypty9 Electrical 3 12-07-2010 07:36 AM
whirpool refrigerator ice make stopped working neadhelp Appliances 2 07-24-2010 12:10 PM
Rheem furnace stopped working kgsolomon1 HVAC 1 02-09-2008 07:51 PM
