One Shower Lower Pressure? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-08-2008, 10:39 PM   #1
One shower lower pressure?
I have a 40 year old home with two bathrooms.
One shower has amazing water pressure and the other is pathetic. It seems to be getting worse in the lower one too. Even with no other outlets open throughout the house, it seems to really be very low. Is there anything I can do to troubleshoot what is causing this?
mqcarpenter is offline   Reply With Quote
Old 11-08-2008, 11:08 PM   #2
biggles's Avatar
is it the hot/cold pressures on all the house water faucets.does the house have copper lines,and how long has this been going on....did you once have great pressure hot and cold?
Old 11-09-2008, 02:30 AM   #3
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
If you have galvinized pipes, then the pipes may be having problems. Otherwise, suspect the valve and think about replacing it.
Does the sink in that bath have low pressure, if yes, lean towards pipes, if no, think shower valve.
Jamie
jamiedolan is offline   Reply With Quote
Old 11-11-2008, 11:38 PM   #4
Jamie
Actually the sink in that bathroom is great. so this is a great indicator. The fixture in the shower is very old so I will look at the valve.
Thanks!
HELP - Lost water pressure to shower after turning off water to house jpw28 Plumbing 8 02-20-2008 09:07 PM
New install shower has poor hot water pressure rwhitne Plumbing 2 01-20-2008 05:13 PM
Hot water pressure in the shower Randy Stuempfig Plumbing 15 01-03-2008 10:58 AM
No Hot Water Pressure In Shower Randy Stuempfig Plumbing 6 01-02-2008 08:35 PM
Shower Pressure Problem rob1970 Plumbing 18 03-10-2007 11:41 AM
