Which One Is The Right Pex Brass Fitting - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-03-2012, 03:39 PM   #1
Which one is the right Pex Brass Fitting
Home tap water system: need to connect a plastic pipe to a copper pipe,
Home depot people say only the first one is right, the 2nd one is for something else:
first one:
http://www.homedepot.ca/product/3-4-...oupling/954440
2nd one:
http://www.homedepot.ca/product/3-4-...oupling/954422
does it really matter?
Thanks!
KJ_Bridge is offline   Reply With Quote
Old 02-03-2012, 03:44 PM   #2
Rewards Points: 256
If you are asking this question, then I'm not sure you are qualified to do this work.
The first one appears to be a sweat to pex transition. The second one is a 1/2 pex to 3/4 pex transition. (Although the pic doesn't match the description.)
michaelcherr is offline   Reply With Quote
Old 02-03-2012, 03:57 PM   #3
So the second one is a pex to pex, thanks!
Old 02-03-2012, 03:59 PM   #4
Civil Engineer
Rewards Points: 4,514
There are many different types of plastic pipe, including PVC, ABS, HDPE, CPVC, PEX, PB, nylon (and a few others I have not mentioned). The correct fitting requires knowledge of the type of pipe. Sometimes it is marked on the pipe itself. Do not rely on a big box store for this type of advice, you need to go to a plumbing supply store. If you are going to install copper anyway, you can remove a few inches of the plastic pipe, and bring it in to the plumbing supply store, they will be able to identify it and give the correct fitting.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
KJ_Bridge (02-03-2012)
Old 02-03-2012, 04:03 PM   #5
I would like to see how this turns out
broox is offline   Reply With Quote
Old 02-03-2012, 04:06 PM   #6
its pex to copper, thanks!
Brass fitting removal starkhd Plumbing 5 12-08-2011 11:09 PM
Brass Fitting Broke Flush on Air Compressor C_J_GO Tools 5 08-04-2011 11:29 AM
CPVC lines with brass fitting mill1500 Plumbing 5 05-19-2011 10:43 AM
Brass fitting help Joe F Plumbing 3 09-22-2009 10:57 AM
How long to heat the brass fitting jgs1951 Plumbing 2 07-22-2009 10:19 PM
