One Handle Shower Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-08-2008, 09:22 AM   #1
i recently bought a delta 13/14 series one handle shower faucet but it didnt give dimensions on how far up to place faucet from shower pan.does any have an idea or can i put it anywere i want?thanks
GLASSMAN1 is offline   Reply With Quote
Old 02-08-2008, 09:40 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Where ever you like to put it.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 02-09-2008, 02:53 AM   #3
Stand in your shower pan and casually stretch your hand out in front of you. Right above waist level, right where it feels right, that's where. It should be between 42-48 inches off the floor. More importantly is the depth of the valve inside the wall. You need to know how thick your finished wall is going to be. With that in mind, your trim plate must go over the valve and secure to the finished wall without the valve sticking out too far(unsightly). If it's too far inside the wall, you may have to buy an extension kit. The other concern is that the shower head comes out of the wall at least 2 inches above any type of surround, fiberglass or tile. It should be approximately 6' 4", remembering that the shower arm and head drops back down 6 inches. If the shower head arm comes out too close to where the tile or surround ends, the trim flange or escutcheon will not mount flush or flat to the finished wall. It will look terrible. Hope this helps.
askaplumber is offline   Reply With Quote
Old 02-09-2008, 04:08 AM   #4
thanks alot guys.
Please help, Stuck cartridge,Moen single handle tub faucet, Woodpecker Plumbing 25 01-26-2014 06:31 PM
two handle shower faucet to single handle GLASSMAN1 Plumbing 2 01-31-2008 09:08 AM
Double Handle versus Single Handle kitchen faucet Lindahoney Plumbing 7 11-20-2007 10:36 AM
3 handle shower epolgar Plumbing 1 08-13-2007 10:02 AM
Symons shower faucet ptedone Plumbing 2 01-01-2007 11:03 PM
