One Big Vs. Two Small Water Heaters - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-13-2011, 02:51 PM   #1
one big vs. two small water heaters
I need more hot water (sometimes). Which is better,one 80 galllon or two 40-50gal? Any thoughts or opinions would be appreciated.
747jetmech is offline   Reply With Quote
Old 02-13-2011, 03:02 PM   #2
Water Treatment
Rewards Points: 900
The heater that you have now is Gas or Elect?
How often are you in need of more hot water than you have?
2 water heaters, one as a pre heat could be one idea.
What is the incoming water temp?
If the first tank tank has a lower setting say lowest then it pre heats the water from 40F to 80F then the recovery of the second tank will be faster because it is going from the 80F to 120F...
Even the first tanks recovery would be better because it is only going from 40F to 80F..
A single tank would have more water to heat from say 40F to the 120F.
Does the need justify the added cost of tanks and fuel to heat the water?
Akpsdvan is offline   Reply With Quote
Old 02-13-2011, 03:13 PM   #3
I have an earlier post in plumbing "water heater woes" explaining my sitiuation. It is electric.
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Have to replace 2 water heaters in house we're buying...help! housenewbie Plumbing 9 01-09-2011 11:55 AM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
