One (1) 1 1/4" Gas Pipe V.s. Two (2) 1" Gas Pipe, Which Is Better? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-15-2010, 12:01 PM   #1
One (1) 1 1/4" gas pipe v.s. two (2) 1" gas pipe, which is better?
My house needs two (2) 1" gas pipe. One for tankless water heater. Another for furnace, stove and dryer.
Is it a better idea to use one 1 1/4" pipe?
My plumber told me it's much harder to work with 1 1/4" pipe. Is it true?
Thanks a lot!
pttcc is offline   Reply With Quote
Old 02-15-2010, 08:35 PM   #2
Depending on how he is equipped it may be harder for him personally. If he has the capability to thread 1 1/4" pipe he would probably do it. I'm guessing he has a hand threader and 1" is the biggest pipe he can thread without borrowing the tooling.
I've run a lot of screw pipe, and I would charge a lot more to run 2 1" pipes the same distance I would a single 1 1/4".
brandonmcginnis is offline   Reply With Quote
Old 02-15-2010, 10:13 PM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Not to mention double the pipe in 1" probably costs more than a single run of 1-1/4 as well.
Journeyman Plumber
Old 02-15-2010, 10:29 PM   #4
I agree with the previous responses.
But, if you still want to use this guy.
Mechanically there is nothing wrong
with running the two 1" pipes
SuperPlumberGuy is offline   Reply With Quote
Old 02-16-2010, 12:35 AM   #5
another thing you'll have to check is the cfh of the meter itself. You are probably way over what a standard meter is capable of. I think a standard one is 275 cfh. You are pushing in the neighborhood of 350 cfh. Usually a meter can accomodate 10% over its rating but even that its just over 300 cfh. Just food for thought
fhrace is offline   Reply With Quote
Old 02-16-2010, 02:01 AM   #6
Thanks to you guys all!
Is there any bad consequences if I have big appliances and 1 1/4" gas pipe with a small meter? (except my water heater/furnace may not go full power together at the same time.)
Old 02-16-2010, 02:56 AM   #7
Rewards Points: 370
The last 1" black pipe I got was $1.35 per foot, the 1.25" was $ 1.83 per foot. So, you will spend $2.70 per foot to run the 1", and twice the labor. Cutting and threading 1.25 will take a little longer than 1", but not much longer, even if he uses a mechanical threader.
fireguy is offline   Reply With Quote
Old 02-16-2010, 11:45 AM   #8
You'll have to check with your local gas company but most times they will just change meters out free of charge for you. I think they jump them up to like 300 cfh or 300,000 btu's. Even look on your meter it will say on there the rating. You can install the large pipe but if your meter can't supply it it still won't work properly.
200,000 for tankless
65,000 for range
35,000 for dryer
90,000 for furnace
So I take back what I said about the 350 cfh its closer to 400cfh. So you can see that if the tankless is running and the furnace. Nothing else will run. But like I said check your meter outside. Maybe it is rated and can handle it. If it can then run the 1 1/4"
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 01:03 PM
Can I go up from 3/4" metal gas pipe to a 1" and then back down? Philip_Soldat Plumbing 3 11-09-2009 10:47 AM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 06:40 PM
Furnace Venting Requirments jamiedolan HVAC 9 11-18-2008 06:40 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 12:09 PM
