Omnifilter Whole House Water Filter Stuck - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-28-2009, 10:15 AM   #1
omnifilter whole house water filter stuck
I moved into the house about a year ago and i when i tried to change the filter for the first time the tank was completely stuck. i have used the wrench that came with it and it still does not move. any suggestions on what i could do to get the tank the tank off.
super is offline   Reply With Quote
Old 03-01-2009, 09:45 PM   #2
Make sure that you have the water turned off and preasure drained down. If it has the bypass on the top try leaving it online but turning the water supply off to the house and draining the preasure. Another tip is to put some silicone or vasaline on the threads and DONT put it back on with the wrench, just hand tight. that will make it alot easier to take off next time.
lilh2o3 is offline   Reply With Quote
Old 03-10-2009, 01:14 AM   #3
removed the filter so that it will change the tank and it might that it will release the leak from the tank..
____________________
Ukf8001axx
jay182009 is offline   Reply With Quote
Old 03-13-2009, 07:43 PM   #4
Rewards Points: 150
vasoline
Only use valve and stem grease.Vasoline is petroleum based and after time can damage plastic and o rings.
rudolph58 is offline   Reply With Quote
Water pressure issues - in one part of the house stream41 Plumbing 4 11-11-2008 07:43 PM
Whole house water filter questions... epeterson777 Plumbing 7 10-12-2008 12:51 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
HELP - Lost water pressure to shower after turning off water to house jpw28 Plumbing 8 02-20-2008 08:07 PM
hot water recirculating/sediment confusing problem rcatty Plumbing 1 01-06-2008 03:51 PM
