OMG...how Long Does It Take To Drain The Water From Your Pipes? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-22-2013, 02:02 PM   #1
Rewards Points: 191
OMG...how long does it take to drain the water from your pipes?
Ive been emptying buckets for like 2 hours...
I have to work on the lowest drain in the house and I've probably emptied like 50 gallons of water. When is this going to stop?!
amateurplumber is offline   Reply With Quote
Old 07-22-2013, 02:33 PM   #2
Rewards Points: 736
Definitely takes longer than you expect. Why are you doing it with buckets instead of a hose?
TheBobmanNH is offline   Reply With Quote
Old 07-22-2013, 02:38 PM   #3
Rewards Points: 191
I can't attach a hose to the basement valve, it's not threaded. I think our shutoff is faulty. 30 year old gate valve. I'm going to just install it since they are quick connects.
Old 07-22-2013, 03:09 PM   #4
Rewards Points: 13,446
Hope your going to change it to a ball valve.
Old 07-22-2013, 03:11 PM   #5
Anyway to just open some outside faucets to drain some of it?
Old 07-22-2013, 04:08 PM   #6
Water Treatment
Rewards Points: 850
If it is going as strong 4 buckets in as it was when you started then I would be looking at the main shut off valve not setting correctly and you might try to close it again.
Akpsdvan is offline   Reply With Quote
Old 07-22-2013, 06:07 PM   #7
DIY staff
Rewards Points: 7,174
Yep--sounds like a bad main shut off---look at the meter--many newer meters have a shut off built into it----
The Following 3 Users Say Thank You to oh'mike For This Useful Post:
ben's plumbing (07-22-2013), COLDIRON (07-23-2013), TheEplumber (07-22-2013)
Old 07-22-2013, 06:08 PM   #8
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,418
How big is your home.... I think your shutoff is bad... especially as I think you said gate valve very old.... you may have to go to the street valve.
Best
MTN REMODEL LLC is online now   Reply With Quote
Old 07-22-2013, 06:40 PM   #9
Plumber
TheEplumber's Avatar
Rewards Points: 554
Usually stops at about a bucket- or less. Especially if all the faucets are off.
You got a valve issue.
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 07-22-2013, 08:26 PM   #10
Just a suggestion, unless your going to solder, you don't need to drain all the water out of the pipe to install sharkbite quick connectors.
jmon is offline   Reply With Quote
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Draining water out of shower pipes docmattman Plumbing 9 05-23-2011 07:43 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
No Cold Water at all - both cold and hot pipes are burning to the touch bluecifer Plumbing 12 01-19-2009 10:29 AM
