-   -   OMG...how long does it take to drain the water from your pipes? (http://www.diychatroom.com/f7/omg-how-long-does-take-drain-water-your-pipes-184053/)
amateurplumber 07-22-2013 02:02 PM
Ive been emptying buckets for like 2 hours...
I have to work on the lowest drain in the house and I've probably emptied like 50 gallons of water. When is this going to stop?! :(
TheBobmanNH 07-22-2013 02:33 PM
Definitely takes longer than you expect. Why are you doing it with buckets instead of a hose?
amateurplumber 07-22-2013 02:38 PM
I can't attach a hose to the basement valve, it's not threaded. I think our shutoff is faulty. 30 year old gate valve. I'm going to just install it since they are quick connects.
joecaption 07-22-2013 03:09 PM
Hope your going to change it to a ball valve.
joecaption 07-22-2013 03:11 PM
Anyway to just open some outside faucets to drain some of it?
Akpsdvan 07-22-2013 04:08 PM
If it is going as strong 4 buckets in as it was when you started then I would be looking at the main shut off valve not setting correctly and you might try to close it again.
oh'mike 07-22-2013 06:07 PM
Yep--sounds like a bad main shut off---look at the meter--many newer meters have a shut off built into it----
MTN REMODEL LLC 07-22-2013 06:08 PM
How big is your home.... I think your shutoff is bad... especially as I think you said gate valve very old.... you may have to go to the street valve.
Best
TheEplumber 07-22-2013 06:40 PM
199 Attachment(s)
Usually stops at about a bucket- or less. Especially if all the faucets are off.
You got a valve issue.
jmon 07-22-2013 08:26 PM
Just a suggestion, unless your going to solder, you don't need to drain all the water out of the pipe to install sharkbite quick connectors.
