Ole' Faucet Leaking... - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree3Likes
  • 1 Post By Ghostmaker
  • 2 Post By Ghostmaker
Old 08-20-2016, 09:34 AM   #1
Rewards Points: 4
Ole' faucet leaking...
Hello .. Requesting repair ideas for a leak in the brass (?) flex pipe in this very old faucet. Pipe has bad leak in the center of the line in the picture. Any ideas appreciated! It's a 8" on center faucet in an old pedestal sink. Thank you.
Ole' faucet leaking...-20160820_102548_resized.jpg   Ole' faucet leaking...-20160820_102642_resized.jpg
Bisseti is offline   Reply With Quote
Old 08-20-2016, 11:37 AM   #2
Oso954's Avatar
Rewards Points: 1,332
Re: Ole' faucet leaking...
I wouldn't waste time tying to repair it.
Replace the line.
Oso954 is online now   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
jmon (08-20-2016)
Old 08-20-2016, 11:58 AM   #3
Rewards Points: 320
Agree with oso.
Turn off water, unscrew it, replace with new flex line. Use some pb blaster or wd40 on the nuts if you have to. Easy fix.
jmon is offline   Reply With Quote
Old 08-20-2016, 01:06 PM   #4
Rewards Points: 2,040
Replace the entire faucet those flex connectors are soldered in place. From 1950-1960 era.
jmon likes this.
Old 08-20-2016, 08:38 PM   #5
Rewards Points: 4
Ghostmaker: Yes they are soldered..any chance I could remove those soldered connections by heating them and cleaning fittings and then using a new 3/8" (it seems) connection of some kind? Changing the faucet will involve cutting it off (nuts are totally rusted) and redoing the drain connection (and expense) trying to avoid that. Thanks for your input.
Old 08-21-2016, 01:11 AM   #6
mOEN 8 INCH SPREAD LAV FAUCET IS $78.00 why bother?
jmon and SHR Plumber like this.
Shower faucet continues leaking after... crossnote Plumbing 11 05-10-2014 04:50 PM
4" centerset single lever faucet leaking Ttd0715 Plumbing 3 12-16-2013 05:46 PM
Leaking faucet..replaced cartridge mrmerck Plumbing 2 03-28-2012 09:23 PM
Faucet leaking on tub, could just be cartridge? GordCooper Plumbing 6 02-16-2012 03:45 PM
shower faucet valve leaking throne7 General DIY Discussions 6 03-13-2010 06:31 AM
