Old 08-08-2006, 09:28 AM   #1
Arrow
Old Water Supply Lines in Kitchen and Bath Faucets
I am in the processing of trying to update my kitchen and bath myself. I eventually want to replace the sinks and faucetsk, but the water supply lines are soldered and not the screw on type. Would this be expensive for me to have a plumber replace the soldered lines with the modern ones? Live in NE PA.
skittlzski is offline   Reply With Quote
Old 08-08-2006, 09:32 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
If the shut offs are compressed onto copper pipe, and you have at least 1" visible pipe on the back side of the shutoff, you can can off the old ones and compress on the new ones, if not then they will need to be sweated off so new one can get installed.
It should not be the expensive to have this done.
Ron The Plumber is offline   Reply With Quote
Old 08-08-2006, 10:13 AM   #3
Thanks!
Tankless hot water heater??? psychocandy Plumbing 1 03-22-2007 11:41 PM
Why doesn't my hot water last? MWM Plumbing 6 04-05-2005 09:58 AM
