Old Water Heaters - Replace Or Wait To Fail? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-03-2011, 06:57 PM   #16
Missouri Bound's Avatar
Originally Posted by djsted View Post
It would be enough said if I knew what you were talking about.
I have 240 run to the existing electric water heater tank. No clue on the amps amount from the breakers.
One 240 volt circuit won't be enough. That's one of the issues with the tankless water heaters. It could require 2 if not more 240 circuits. And when your electric bill is calculated, it is based not only on usage, but on demand. When the tankless kicks in, your meter registers the surge and that is what you pay for. I'll say a bit more about the regular electric or gas water heaters.....they don't run all day to keep the water hot. The insulation is very good and more than likely they will keep the water hot all day without coming on. At least mine does (did).
Water Heater: Replace or Not? AZSun Plumbing 4 08-25-2011 11:54 PM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 11:32 AM
Long wait for hot water Kuma450 Plumbing 2 02-10-2010 12:48 PM
Hot water heater - Should we replace it?? liberty610 Plumbing 26 12-12-2009 11:23 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
