Old Toilet Flange On Cast Iron Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-02-2010, 06:14 PM   #1
Old Toilet Flange on cast iron pipe
This toilet has probably been sitting here for the greater half of a century. It began leaking onto the floor so I decided it would be a good idea to replace the wax ring. First, this toilet had four bolts. Two of which were mounted into the bare tile and two into what I believe is the flange. When removing I discovered that only one was not complete rusted out. After scrubbing for about 3 hours here is the result. They must have used some clay type of wax ring. I can't tell where the wax ring starts and the flange begins. It is all very dense material a little more than my flimsy putty knife can handle. I don't think it will be possible to salvage the existing flange. I was thinking of getting a "super flange" or some sort of compression flange. Any suggestions?
Old Toilet Flange on cast iron pipe-100_2570.jpg   Old Toilet Flange on cast iron pipe-100_2573.jpg
ahuberpsu is offline   Reply With Quote
Old 05-02-2010, 09:51 PM   #2
Military Mom of 4
Snav's Avatar
What type of access to the plumbing do you have?
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 05-02-2010, 10:09 PM   #3
It is partially embedded in the plaster ceiling of my garage. it doesn't go very far before it meets the sink and main drain lines.
Old 05-16-2010, 03:43 PM   #4
So I had a plumber look at it. I did not even have a flange! This is common in houses built in the 50s and earlier.
My neighbor lent me a tool to grind down the excess pipe. I bent the bolt until it broke at the floor and used the tool to grind everything pretty smooth to the surface of the tiles.
I used a putty knife to get the crud off the inside of the pipe.
Then I installed a twist and set flange. You place it inside the pipe, twisting it will raise a rubber seal until it is tight inside your pipe. I then mounted it to the floor with screws.
I installed a new toilet and everything is working great!
Old 05-17-2010, 07:04 AM   #5
Military Mom of 4
Snav's Avatar
Well awesome - nothing but a little ingenuity and you figured it out!
Sorry to reply to yur thread and then leave you hanging!
Uneven toilet flange alqugrub Plumbing 6 08-27-2012 08:16 PM
Replacing basement toilet - what to do about flange mslide Plumbing 4 12-20-2009 07:54 AM
Repair of cast iron sewer pipe within concrete cando Plumbing 5 04-22-2009 11:10 PM
cast iron flange Jrebhun Plumbing 2 09-06-2008 12:45 PM
Cast iron and rusty pipe question snowens Plumbing 2 07-27-2008 10:07 AM
