Old Style Cast Iron Radiator - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-18-2012, 07:10 PM   #1
old style cast iron radiator
there is no heat coming from the radiator
ed leadbetter is offline   Reply With Quote
Old 11-18-2012, 07:13 PM   #2
Rewards Points: 6,652
Is the boiler turned on.
Old 11-18-2012, 07:22 PM   #3
Rewards Points: 14,020
Is the valve open?
Old 11-18-2012, 09:21 PM   #4
Rewards Points: 1,538
Steam or forced hot water?
For steam, is the air valve working properly? (You can actually test the system by removing the air valve, seeing if after a few minutes, steam comes out of the hole. After the air inside has been displaced by steam, you can plug the air valve hole and the radiator will continue accepting steam and will heat up well. After the furnace kicks off and steam stops coming up the inlet pipe, air must be allowed to re-enter the radiator. Do not leave the air valve hole open; lots of steam will billow out and make the room very humid, as well as cause the furnace to run dry.
Replacing cast iron HW radiator distribution with PEX-Al-PEX silvajus HVAC 1 02-07-2012 02:39 PM
How do I reinstall a cast iron radiator? robgettings Plumbing 6 11-03-2011 06:08 PM
cast iron radiator garrreee Plumbing 0 11-28-2010 06:05 PM
Refilling Cast Iron Radiator System mbrenning0803 Plumbing 2 10-21-2010 09:00 AM
Removing a Cast Iron Radiator MugsynSax Plumbing 1 10-05-2009 04:18 PM
