Old Steel Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-08-2012, 09:24 AM   #1
old steel pipe
I have old steel pipe in my house it was build in the 50s dont have any trouble with it right now but its not insul and is it something i can do changing it out to pvc or should i just leave it alone i live in alabama
buddy hathorn is offline   Reply With Quote
Old 03-08-2012, 12:57 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 350
It will start failing eventually. My pipe is the same age and I have no issues. It really depends on your water quality.
A few people here will tell you to rip it out immediately
Whatever you decide, don't use PVC as it is not approved for indoor use, nor is it allowed for HW use. I suggest PEX.
Do you have problems now?
Old 03-08-2012, 01:50 PM   #3
Rewards Points: 2,238
Just for some clarification -
Are you talking "steel pipe" for your drains or your water supply lines?
RF
rossfingal is offline   Reply With Quote
Old 03-08-2012, 02:58 PM   #4
Rewards Points: 616
once they go they go and my crystal ball is not working to let you know when
on a serious note if you are talking supply lines i would change them to pex easy to run and very cost effective as a person in the field i have a lot of good things to say about pex and one bad and that is it is to easy to install so i lose some work occasionally due to that and when you do switch the odds are it will increase your water pressure/volume
if you are talking about drain i would switch to pvc all at once is best option but at least each branch as it leaks or constantly clogs
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 03-08-2012, 07:35 PM   #5
steel pipes
if i run pex line do i need to insul it as i go they are my supply lines thanks for your help
Old 03-08-2012, 07:52 PM   #6
Rewards Points: 1,528
Where do you live? If it doesn't get cold not as critical but typically water lines are on the inside of heating envelope of the house so they don't need to be insulated. Pex is likely more forgiving than your steel pipe when it comes to freezing I'd think so if the steel isn't insulated now, the pex likely would not need to be; your mileage may vary.
bob22 is offline   Reply With Quote
The Following User Says Thank You to bob22 For This Useful Post:
jaydevries (03-08-2012)
Old 03-08-2012, 10:51 PM   #7
What is PVC for? Is it for potable water?
Hardway is offline   Reply With Quote
Old 03-08-2012, 11:16 PM   #8
Plumber
Rewards Points: 350
Yes, it's for potable water but most plumbing codes don't allow it inside a house. It's fine for distribution piping outside though
Why do they make copper plated steel pipe hangers? tractorfarmer Plumbing 0 01-15-2012 07:55 PM
anybody want to clear something up for me? Pressure bfan781 Plumbing 10 06-12-2011 07:52 PM
removing Cast Iron drain pipe jimmyfloyd Plumbing 1 01-04-2011 04:47 PM
Exterior Furnace exhaust vent pipe NeedHomeRepair HVAC 1 12-20-2010 06:17 PM
burying galvanized steel pipe amakarevic Plumbing 9 08-19-2008 11:37 AM
