Old Standing Oil Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-16-2009, 09:18 AM   #1
Old standing oil tank
My house was converted to gas heat before I bought it. But They left an old metal oil tank in the basement. Its a major space waster. It seems empty. I want it out of my house. I live in New Jersey. I don't know the safety and legal guidelines. Can anyone help me. Can I cut it out myself with a recip saw? Or do I need a licensed contractor in that field to remove it?
mike1w is offline   Reply With Quote
Old 10-16-2009, 10:00 AM   #2
If there is any way to get it out whole, thats the way to go. There will still be oil and sludge in the bottom that can cause a big mess.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 10-16-2009, 10:11 AM   #3
Oil tank
That is not an option, due to size and layout.
Old 10-16-2009, 10:25 AM   #4
Thats what I figured. With all the environmental rules now, you may even have a problem getting rid of the pieces. I would suggest calling an oil supply company and inquiring what all your options are. Phone call is cheaper at this time.
Old 10-16-2009, 11:10 AM   #5
Of course, in the image,
http://homepro-co.com/Images/oil_tank.jpg
the broader side is the weakest as far as resisting a bending or crushing force.
Can you crush the tank so that it buckles and then get it out?
You'd need some heavy hammers or you'd need to raise a very heavy weight with block and tackle and then drop it on the tank.
Or, with a vacuum pump evacuating all the air out, atmospheric pressure at 2000#/sq. ft. might crush the tank. Or use the pump and the hammer.
Once it buckles you may be able to crush it further with a come-along.
Do not qualify for a Darwin Award. This project has the potential for injury.
Old 10-16-2009, 10:26 PM   #6
Rewards Points: 1,536
If you do it yourself you can cut down on the mess by cutting up the top 3/4 of the tank in any fashion you wish, leaving the bottom 1/4 in one piece. Then siphon out any loose oil and put that in a paint can or jar, then scoop out any sludge and put that in another paint can or large jar.
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Nightmare water tank job Marvin Gardens Plumbing 6 11-04-2008 11:09 AM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 11:19 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
