Old School - Sweating Copper Pipe Vs Sharkbite - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-10-2014, 11:22 PM   #1
Old School - Sweating Copper Pipe vs Sharkbite
I was recently at Home Depot's plumbing department and I was looking for a certain type of ball valve so I asked the guy there. He then started to tell me about this new push and click system called Sharkbite. I told the guy that I prefer to sweat my copper pipe together but he kept pushing, telling me about the guarantee and the reliability. In the end, he offered to give me the sharkbite valve and connector for free just so that I would try it. I still didn't 'bite'. I just don't trust these new systems with plastic pipes and all of these different pressure fitting. Solder, flux, and a blow torch are the most reliable plumbing tools for me. Do others feel this way or am I just old school?
Cheers
Brad
maltonmanor is offline   Reply With Quote
Old 04-11-2014, 06:02 AM   #2
Rewards Points: 320
Not so much old school, a lot of professional plumbers also feel the way you do. You have the skills, experience, and knowledge needed for sweating copper pipe, which is great, others may not.
For the average homeowner sharkbite is another safe option so they can fix the leak, not get burned or possibly start a fire/burn the house down.
Personally, I like them and have used them on many occasions. Haven't had any leaks with them yet. You have to make sure they are installed correctly or they will leak. Just my thoughts.
Stay tuned, this topic has been brought up many times on this forum, lets hear what the plumbers have to say. Thanks.
jmon is offline   Reply With Quote
Old 04-11-2014, 07:47 AM   #3
Rewards Points: 14,000
When I see questions like this it makes me think about the first fiberglass sales person going to the local boat yards and holding up a piece of fiberglass mat and telling this is the future of boat building. They must have thought he was crazy.
Or the first PCV salesman, that's never going to work.
Old 04-11-2014, 09:18 AM   #4
Rewards Points: 1,684
Tubeless tire?? What in he!! will they think of next.
Old 04-11-2014, 09:27 AM   #5
PoleCat's Avatar
Rewards Points: 1,652
I'm still not warming up to pex. My cousin's softener & water heater connection looks like a clown's balloon animal attempt.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
The Following User Says Thank You to PoleCat For This Useful Post:
TheEplumber (04-11-2014)
Old 04-11-2014, 10:50 AM   #6
Rewards Points: 790
I too have used a shark bite valve when I installed a new water heater. Very easy and no problems. I once was testing the connection at a big box store just to see how it worked....well, I connected the fitting to a pipe and there's no way that was ever coming off. If you have the tools and ability to sweat....awesome. If not, the options seem to be limitless.
cibula11 is offline   Reply With Quote
Old 04-11-2014, 11:16 AM   #7
FIDO...
Rewards Points: 241
Originally Posted by maltonmanor View Post
... In the end, he offered to give me the sharkbite valve and connector for free just so that I would try it...
Note to self: Self, next time you need some SharkBite fittings, go to HD and score some free ones by playing the skeptic.
Cheers, Chris
Chris130 is online now   Reply With Quote
The Following 2 Users Say Thank You to Chris130 For This Useful Post:
jmon (04-11-2014), MTN REMODEL LLC (04-12-2014)
Old 04-11-2014, 10:14 PM   #8
Master Plumber
Javiles's Avatar
Rewards Points: 996
I got four sharkbite fittings in my truck brass junk bucket,, just replaced them today all leaking..
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 04-11-2014, 10:35 PM   #9
Plumber
TheEplumber's Avatar
Rewards Points: 812
I told you not to use those- but you didn't listen.........
Old 04-11-2014, 11:15 PM   #10
Rob
Robpo's Avatar
Rewards Points: 826
I don't know about the sharkbite but I would use them if I had no other option. I used Rehau Pex in my home for domestic water because my wife wanted a separate line for each fixture( no tees with 2 manifolds). I think it would have cost more it I would have used copper. I use soldered copper to heat everything above ground on my solar radiant floor heat and hot potable water and Pex with ferrules and stiffener under ground. Haven't had any problems yet but its only been 6 years.
Robpo is offline   Reply With Quote
Old 04-11-2014, 11:15 PM   #11
Lord of Slums
Rewards Points: 1,974
I had too fix so many broken pipes this winter I just used hose and hose clamps. Worked great. Have been going back and sweating everything back together. It is surprising how easy it is too solder when it is sunny and 70 outside.
mj12 is offline   Reply With Quote
Old 04-12-2014, 11:54 AM   #12
Rewards Points: 2,038
I solder it's fixed the first time. I sharkbyte god only knows how long it will last.
Old 04-12-2014, 12:01 PM   #13
If I can get the pipe dry it's a snap but I didn't have enough money remaining after buying solder to buy a loaf of white bread.
Two applications here at the ranch that have farmer's co-op 1" radiator hose. Both at the well pressure tanks. One has been there 35 years and the other 5. Works great.
Old 04-12-2014, 04:40 PM   #14
Rewards Points: 582
contractor on the condo job were doing ...broke some lines while digging..he and his son thougth they would repair with sharkbite and not tell me.....well guess what... they are leaking....
Old 04-12-2014, 05:33 PM   #15
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
As long as if not longer then the solder when installed correctly.
sublime2 is offline   Reply With Quote
Analyzing My Copper Pipe Sweating After 12 Years ddawg16 Plumbing 3 12-27-2012 04:16 PM
Removing pipe wrap around copper pipe steve3847 Plumbing 1 12-25-2012 02:46 PM
How To Bring Copper Pipe Through Concrete Block Starlight Plumbing 14 12-15-2012 07:48 AM
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
Septic Odor from Hole in Copper Pipe kita123 Plumbing 1 04-03-2012 08:22 PM
