06-26-2012, 08:37 PM
#1
Old School Cast Iron Pipe Repair
Hello,
I am trying to repair a cracked pipe in a very old building. The drainage is made of old cast iron pipe. The problematic area is as follows, a "Y" connection, to a 6" straight pipe, threaded into a threaded collar. The 6" pipe is cracked and threaded on both ends. The threaded joints seem rusty. The people at the hardware stores seem to be unfamilar with cast iron pipes. It seems like the best advice I got so far was;
Cut the 6" pipe down the middle, unthread both ends, thread in ABS adapters, and glue in about 6" of straight pipe.
Questions:
Is this the way to go?
If so, won't unscrewing the pipe be murder, is there a trick of the trade, like torching it.
Thanks for the help.
06-26-2012, 09:34 PM
#2
Post a picture, without it, everyone's going to be guessing.
06-26-2012, 09:50 PM
#3
MarginallyQualified
You keep saying cast...
Well, maybe they're just unfamiliar with threaded cast iron pipe?
I have to admit that I am as well.
Cut the 6" pipe... adapt... and glue in (new) pipe.
Close to.
Post a couple of clear pictures.
06-26-2012, 10:09 PM
#4
Super Moderator
Cast iron is never threaded---galvanized steel is.
Chances of unscrewing that rotted pipe are slim--
Yes--torching the pipe and cooling it will help
Pictures please---
06-26-2012, 10:42 PM
#5
Sorry about the pic, here it is ...
You may be right, it may be galvanised, hard for me to tell.
06-26-2012, 11:07 PM
#6
MarginallyQualified
You might be able to set a patch fitting over the split.
If that won't do it... I sure don't envy you this job.
Look for something like this:
06-27-2012, 11:56 AM
#7
That's galvinized pipe,isn't there a union anywhere close?
06-27-2012, 12:35 PM
#8
call me E
Not too many unions in DWV piping.
Best to take out as much pipe as possible and replace with plastic. That pic only shows one bad spot. Bet there's more coming...
06-27-2012, 09:09 PM
#9
Hi Guys,
Thanks for all the great advice, I'm glad I was able to provide so much entertainment for you
Sorry I wandered onto this forum, I'm actually a HVAC guy, and missed the part where I ended up on the pro-plumber forum. I was seeking advice but seem to have ended up in the wrong forum, but at least you guys got some laughs, all is well that ends well. So now I know it galv steel, and lead pipes don't have threads, I got something out of this!
If you do have so good advice thanks, else I'll let you know how the spray foam ends up
Take care boys, sorry again.
06-28-2012, 01:19 AM
#10
retired elect/hvac/plumb
I didnt notice anybody laughing at you,and yes thats galvanized pipe.
Where does the pipe go once it leaves the next fitting?
"facts" have no relevance to this discusion To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Posting from a concrete bunker under a non descript barn
06-28-2012, 06:55 AM
#11
My last reply was intended for another forum, I wandered onto a forum for pro's and they had fun with the responses.
The advice I got here was actually great. I just need to find the patch fitting, home depot does not have it, and plumbing stores are harder to find, so I have an exercise with the yellow pages.
The pipe leads into a threaded sleeve and then another straight run of quite a few inches. Why do you ask, I can maybe provide better info if I know what you are looking for.
06-28-2012, 07:02 AM
#12
Super Moderator
Take a picture from farther back--It might be easier to cut out the Y and the Iron fitting ahead of the bad section--then use rubber Fernco fitting---and convert the whole assembly to PVC.
06-28-2012, 07:09 AM
#13
If it goes up into a wall it might be a good idea to open it up and check condition of rest of pipe,might also be easier to go ahead and tie into a solid piece higher up using a no-hub coupling instead of trying to piece together between offsets going into the wall.
The Following User Says Thank You to plummen For This Useful Post:
06-28-2012, 07:22 AM
#14
I Guarantee you if the pipe is damaged that much in that spot the whole line is damaged, I'd just cut it all out and install PVC as previously mentioned by others. In fact I think it would be easier to replace the line than repair it and Peace of Mind.
You know it's just like light bulbs when one burns out replace all of them, when you replace a tire on the car you replace both sides never just one.
06-28-2012, 07:50 AM
#15
MarginallyQualified
There is ZERO doubt that this will need to be done... at some point.
Don't patch fix this and then bury it behind a finished wall or ceiling.
If the pipe can remain exposed as it is now then my suggestion remains that if the ONE patch can solve the immediate problem that should buy you a few years before you need to do more. But it's still a delay tactic.
The Following User Says Thank You to TarheelTerp For This Useful Post:
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
