Old RO System Needs Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-03-2012, 04:06 PM   #1
Old RO system needs help
I have an older Aqua pure RO system that is not functioning and found this site in hopes of help. I have changed the pre-filter and the 2 post filters and and also the membrane. I have water press. intering the system and none exiting. I can't find my instuction sheet and was hoping someone may be able to tell me what model # this 20yr old system is. I'm sure I have the tubing right but would like to see a diagram to be sure. Could it be that reg. on top of unit?
Thanks all,
Oakfall
oakfall is offline   Reply With Quote
Old 11-03-2012, 04:29 PM   #2
Water Treatment
Rewards Points: 848
Might you have a photo? or the model number if there is one?
Akpsdvan is offline   Reply With Quote
Old 11-03-2012, 05:03 PM   #3
I can't find a model # anywhere. It has the 3 filter housings with the membrane on top going to a white plastic storage tank. I've changed the filters and even the faucet and no go. The only thing left(unless I screwed up) is that juction on top of filter housing. Some kind of a mixing regulator? bought the unit at Graingers years ago. Will take photo soon.
Thanks so much, Oakfall
Old 11-03-2012, 05:43 PM   #4
Water Treatment
Rewards Points: 848
There is an auto shut off valve, two on one side and one on the other.
There should be some arrows on there some place showing which way the flow should go.
Old 11-03-2012, 05:53 PM   #5
Thanks for the help. I'll check it.
Old 11-03-2012, 05:58 PM   #6
Rewards Points: 13,300
Help me out here for my own info. What is it about the water that makes you think it's even needed?
Never could understand all that expence, and maintance required.
Old 11-03-2012, 08:29 PM   #7
we have it for one reason- salt in drinking water,deep well.
Old low voltage lighting system - switches stopped working. zepman Electrical 14 02-17-2016 08:18 PM
Boiler system not completely filling? jeffro83 HVAC 9 08-31-2012 12:56 PM
Electric Run, Voltage Drop Issues. Eventual upgrade of system this year. lawnphysics Electrical 4 04-06-2011 07:24 PM
Need advice RE: purging air from baseboard hot water heating system mikenri HVAC 2 01-19-2011 08:17 PM
beware humidity system? Emaderton3 HVAC 5 02-11-2010 12:52 AM
