Old Pipes Don't Fit The New Fixtures - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-22-2009, 08:38 PM   #1
Talking
Old Pipes don't fit the new fixtures
Hi, I am replacing the bath tub shower faucet. Original is 20+ years old with 1 inch inlet pipes. The new ones all seem to be 1/2 inch.
The old one was leaking from the Cold handle. Now that I took it off and put it back on the leak is much worse.
Help
Texllama is offline   Reply With Quote
Old 11-22-2009, 10:13 PM   #2
Rewards Points: 47
1" Inlet !!!??? Are you sure? Never seen that before. Sounds like you got some plumbing ahead of you. The fact that an old fixture leaks worse after you mess with it is not unusual. Those old packings and washers don't take kindly to fresh air and will often crumble or break. Have fun.
LeakyMike is offline   Reply With Quote
Old 11-22-2009, 10:49 PM   #3
Question
Yes. But 1" supply pipes??? Galvanized pipe used to come in 3/4"! Also. the Plumbing Supply store or Home Center have reducing fittings!
spark plug is offline   Reply With Quote
Tags
bath tub , replace , shower faucet
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 08:22 AM
How to (retrofit) insulate/air seal cantilever with hot water pipes in it? KatieAK Remodeling 7 11-04-2009 09:10 AM
How to (retrofit) insulate/air seal cantilever with hot water pipes in it? KatieAK HVAC 5 11-01-2009 09:15 PM
insulating heated garage(retrofit)- insul. & pipes KatieAK Building & Construction 0 10-25-2009 10:03 PM
Master Bathroom Fixtures mpt1123 Plumbing 1 03-01-2009 05:08 PM
