Old 09-30-2011, 11:33 PM   #1
Old houses have no main drain cleanout?
I'm looking at a condo built in 1965. The building inspector found clean outs for kitchen and baths, but no main clean out. He says there might not be a main clean out for a building that old.
Is this true? If there is one, hidden somewhere, where would it be? Would the hoa know where the main drain runs?
darsunt is offline   Reply With Quote
Old 09-30-2011, 11:40 PM   #2
Super Moderator
Very common for a building not to have a main clean out plug---
As to the exact location of the sewer---if you ever need to know a plumber has a number of ways to find it--cameras--and locator balls that get flushed down the toilet and send signals to a sensor as the head to the street---Mike---
Old 10-01-2011, 12:23 AM   #3
call me E
TheEplumber's Avatar
Its not uncommon for clean outs to covered to be covered by sheet rock or under flooring.
drain cleanout BlueBSH Plumbing 1 08-18-2011 04:48 PM
AC drain pipe vent trap going dry - sewage smell denemante Plumbing 6 04-26-2011 07:52 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
roots in main drain jerry1967 Plumbing 5 10-28-2008 04:57 PM
Main drain line lmanwarren Plumbing 1 04-06-2006 01:32 AM
