| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
Most people think about their water heater only when it fails. It's one of those things you couldn't live without, but as long as it does its job, you ignore it. And when it breaks down, you have no idea what to do. You can replace that old water heater... Read More »
How to Thaw Frozen Pipes
by eHow.com
If you live in a cold climate, the risk of frozen pipes is always there. The key is to find them early and thaw them as quickly as possible. Here are some hot tips for cold pipes. Read More »
by eHow.com
If you live in a part of the country where the temperature gets down below freezing, you just might run into the problem of having your water or drain pipes freeze. As long as you’re home (and not off vacationing somewhere warm) you can usually fix... Read More »
The Dangers of Cooking with Oil
by Expert Village
My name is Brandon Sarkis on behalf of Expert Village. Today I am going to be showing you how to make Gourmet French Fries cooked in duck fat. So we are currently heating up the oil and at this point, you are going to want to be very very careful unless... Read More »
How to Insulate a Water Heater
by eHow.com
This is an easy project that not only benefits the environment, but saves you money on your power bills. Having your water heater properly insulated results is less heat loss. So all the energy is spent on heating the water you will use, not wasted in... Read More »
