Old House Due For Hot Water Update? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-12-2010, 08:25 AM   #1
old house due for hot water update?
We bought a circa 1900 house in which the hot water is generated from a 20yr old furnace. It all works fine, no an issue except that in showering, temp has to be adjusted by turning the cold water down slowly as the shower progresses. No real problem as we don't run out of hot water. I've read a reservoir tank can be added to the furnace OR that an separate hot water tank can be added. Is one significantly better than the other and would either change the temp control issue during showering? Maybe one thing has nothing to do with the other? Thanks very much.
kentannenbaum is offline   Reply With Quote
Old 07-12-2010, 10:12 AM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
A reservoir would only work I think if you had a pump on the line to circulate the water through the furnace, otherwise your tank is only going to be storing cold water. I don't know what kind of furnace you have, or anything about your system either, this may not be efficient at all. You'd also need an aquastat in the tank to tell the pump to turn off when the tank reached desired temp.
Maybe someone else will have a better idea.
Journeyman Plumber
Old 07-12-2010, 10:30 AM   #3
Thanks for the reply. By "reservoir" I mean the furnace currently provides heat as well as provides hot water. It's designed that way. Probably, the correct way to ask about this is that a another zone would need to be installed with a holding tank for the hot water alone OR a stand alone hot water tank could be installed. Hopefully that's more clear in my question.
Old 07-12-2010, 10:55 AM   #4
Where are you located ?
What fuel source ?
Old 07-12-2010, 10:57 AM   #5
Catskill, NY.......oil furnace.
Anoying sound in house water pipes when sprinklers are ON gante Plumbing 1 06-07-2010 07:04 AM
Water pooling next to house foundation pictures - help suggestions Steelmesh Building & Construction 8 07-03-2009 11:05 AM
Very Low Hot Water Pressure. PAS1970 General DIY Discussions 2 02-25-2009 04:01 PM
Loss of water pressure in my house... stormyjas Plumbing 6 02-15-2007 11:36 AM
