Old Gas Line Has Funny Smell - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-22-2011, 11:02 PM   #1
Rewards Points: 156
Old gas line has funny smell
As far as I know, it's always had this smell. It's hard to describe but it's only something you notice when right up next to the black pipe in one area. Is this an indication that there's a leak? My natural gas usage is zero for about three or four months of the year (I have an electric water heater) but is it possible that it's so small that it doesn't show up in my meter readings?
strategery is offline   Reply With Quote
Old 09-23-2011, 06:36 AM   #2
Natural gas is odorless and treated with the stuff that makes it smell. If you smell it and are unsure what to do, call power company. Any leak, no matter how small needs to be fixed!!!!
Old 09-24-2011, 09:23 AM   #3
Plumb or Die!
Mix 1/4 cup of dishsoap with water in a spray bottle, and spray the area where you think the leak is. All the joints, even the pipe. If you have a leak, bubbles will show.
plumber666 is offline   Reply With Quote
Old 09-24-2011, 10:04 AM   #4
biggles's Avatar
is it what smells like when you turn the stove on before lighting....
Old 12-08-2011, 10:35 PM   #5
Rewards Points: 156
Tomorrow I'm having the gas leak fixed and the gas line to the kitchen removed. I used the soap water testing method and I do have a small gas leak.
Is black iron pipe still the best material for natural gas lines?
Old 12-09-2011, 05:39 AM   #6
DIY staff
Rewards Points: 7,174
Black iron is still the best---
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 10:21 AM
New ICe maker line causes ice to taste like rubber speedster1 Plumbing 5 06-27-2010 08:09 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Studor Mystery: Sewer Gas Smell StudorCrazy Plumbing 3 02-20-2010 11:49 AM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 06:09 PM
