#1 |
Old Galvanized Waste pipe
My house was built in 1950's and I am adding on, which includes a master bath. I want to run PVC for all of the waste lines but I need to tie into the exsisting. The exsisting is 6'' galvanized. How can I tie into this the best way and keep to code (Ohio). I have seen rubber-like boots used but I am sure that is enough.
#2 |
Long-Time DIYer
Check with your local Building Inspection department for local code, but I'm sure that they allow either a Fernco (rubber) coupling or a no-hub (rubber with stainless steel sleeve) coupling to connect them.
Good luck! Mike |
| Display Modes | |
| Use of coupling fitting on gas pipe | Fred | Plumbing | 3 | 01-28-2007 07:13 AM |
| Replacement pipe for hot water heat? | Tmb9862 | HVAC | 18 | 01-12-2007 04:31 PM |
| Waste pipe odor in garage? | Kirsten | Plumbing | 3 | 11-21-2006 01:07 PM |
| Leaking waste pipe | guvlin444 | Plumbing | 5 | 09-30-2006 02:36 PM |
| Need to support 15th of ABS pipe | irishtimes101 | Plumbing | 3 | 09-01-2006 12:09 PM |
