-   -   Old Galvanized Waste pipe (http://www.diychatroom.com/f7/old-galvanized-waste-pipe-6778/)
rodg2915 02-28-2007 01:35 PM
My house was built in 1950's and I am adding on, which includes a master bath. I want to run PVC for all of the waste lines but I need to tie into the exsisting. The exsisting is 6'' galvanized. How can I tie into this the best way and keep to code (Ohio). I have seen rubber-like boots used but I am sure that is enough.
Mike Swearingen 02-28-2007 02:39 PM
Check with your local Building Inspection department for local code, but I'm sure that they allow either a Fernco (rubber) coupling or a no-hub (rubber with stainless steel sleeve) coupling to connect them.
Good luck!
Mike
