Old Galvanized Shower/bath Inlets Relpace Pex? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-08-2008, 03:42 PM   #1
Unhappy
Old Galvanized shower/bath inlets Relpace Pex?
Hi!
The Shower bath is nothing fancy, just two knobs Hot-cold and a knob that switches to shower-bath function.
I have to replace very old galvanized inlet water pipes to the shower/bath, with pex pipe.
It looks like the old galvanized pipes are threaded into the fixture(s) hot/cold that look like brass that have a nut at the very top and taper to where the galvanized pipe is threaded in.
Im hoping to use adaptor 'Flare-it' 1/2 x 1/2 that will hopfully thread into the inlets...
Question, do I have to cut the galvanized pipe to loosen it from the brass fitting?
Will a regular pipe cutter do the job?
What if the brass and galvanized metal have seized, how can they be loosened?
Thank You!
sssalas is offline   Reply With Quote
Old 09-08-2008, 04:37 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
If your shower is old enough to be plumbed with galv., I think it is time to spring for a new valve along with the PEX re-plumb.
rjniles is offline   Reply With Quote
Old 09-08-2008, 04:56 PM   #3
Unhappy
Valve Replacement?
Thank You for Your Reply!
If I got a new valve thing ( I think your talking about all those other little pipe things; with one that runs up to the shower). Then all I would have to do is cut the inlet galvanized lines?
Ive read other posts where I think they are talking about the "valve tjhing" sweating fixutes; would I have to do that too??
Tags
shower bath water lines
Cast iron vs galvanized steel. duffers Plumbing 10 08-04-2009 11:35 PM
Darn. A leak in my main supply from street, Galvanized. In foundation under slab? twilightcall Plumbing 2 07-31-2008 01:22 AM
Galvanized Flashing with ACQ Treated Lumber? Ler0y Jenkins General DIY Discussions 5 05-18-2008 11:59 AM
repairing old galvanized pipe? darsunt Plumbing 2 04-08-2008 01:39 AM
How to paint a galvanized roof? martyshel Painting 1 07-19-2007 01:44 PM
