#1 |
Old eljer toilet with flush ball (no flapper) leaks
I have an old Eljer toilet in my old house
there's a date on there stamped in 1967. I bought my house just over 2 years ago but hardly used this toilet. I noticed it was leaking a little from the tank to the tub, so I replaced the flush ball from Home Depot. It doesn't have a flapper. The replacement part looks to be the correct size etc of the other one. But to my dismay, it made the leaking even worse. I've played around with the positioning of the flush ball several times but it leaks It's leaking into the bowl, so every 5 minutes the flush valve will come on. I also made sure it was nice and clean where the water outlet is in the tank.Any other suggestions? It's only a $2 part and I replaced the fill valve just fine. Should I just give up on it and replace the toilet?
#2 |
Flapper seat corroded would be one of my first guesses, second would be miss aligned of sticking rod that's attached to the flapper.
Go on the Fluid Master web site to see other options avalible that would work better then what you have now. |
#3 |
retired elect/hvac/plumb
Try sanding the area that it sits against,if all else fails slop some plumbers grease or vaseline around the area it seals against
"facts" have no relevance to this discusion To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Posting from a concrete bunker under a non descript barn |
#4 |
try a plumbing supply house ask for eljer triple seal ball Iam sure its still available..but may be hard to find...even can try ebay?
#5 |
Fuild Master sells glue on seats is that's what's pitted.
#6 |
I'll try the suggestions :D There's no metal down there on this toilet, it's all ceramic (or porcelain...)
#7 |
Master Plumber
The leak may not be from the seal. See your over tube from the fill valve, that comes with a plastic clip, the over flow tube must be above the water line in the tank. If its below the water line it will siphon the water from the tank and into the bowl through the over flow, thus causing the fill valve to run on and off to replace the water. You think it’s the ball but it’s not. That being said that’s a poor and problematic flush valve on those toilets recommend you replace the toilet.
Experience is Knowing what to do next, Skill is knowing how to do it To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#8 | |
Old eljer toilet with flush ball (no flapper) leaksQuote:
I'll give one last ditch effort to save this toilet, if not it's getting replaced. With the tank ball design it takes too much force to flush it
#9 |
Master Plumber
You did not understand me the little black hose that comes off the fill valve goes into that cast in over flow aim looking at it in the picture, I run in to this all the time on running toilet calls that hose is below the water level in the tank. Take that little black hose and find a way to hold it in place above that over flow tube the fluid master comes with a clip and if you notice that clip would clip on to a plastic over flow that’s attached to a standard flush valve about a ¼” above the over flow creating an air gap, may not be your whole problem but its part.
http://www.plumbingsupply.com/how-to...ster-400a.html
Experience is Knowing what to do next, Skill is knowing how to do it To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Javiles; 02-12-2012 at 11:04 AM. |
#10 |
Master Plumber
Also depending on the new rubber seal you got, if its old new stock or depending on the manufacture the rubber may be stiffer, it may take a couple days before it soften and molds to the seating area
Experience is Knowing what to do next, Skill is knowing how to do it To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Javiles; 02-12-2012 at 11:17 AM. |
#11 |
Master Plumber
They also make a retro fit kit for that toilet if the problem is the wire and guide assembly. If you still want to hang on to that toilet, I have used these before and they worked well never got a call back on them. About 20 bucks. it attaches to the tank to bowl toilet bolt, the one next to the fill valve. they make 2 one with touch handle and one with trip lever
#12 | |||
#13 |
Try the vaseline/plumbers grease trick around the area where it seats
#14 | |
| Display Modes | |
| Installing toilet on a concrete floor, Can't find a flange that will fit flush to the floor | Pete R. | Plumbing | 1 | 10-09-2010 06:33 PM |
| Toilet doesn't flush every time | KE2KB | Plumbing | 6 | 03-11-2010 08:18 AM |
| Eljer toilet repair | KAParrish | Plumbing | 3 | 01-29-2010 08:13 AM |
| Toilet Issue - Flap Sticking to Ball | booyah | Plumbing | 3 | 01-14-2010 09:38 PM |
| Eljer toilet parts | Roy Rowlett | Plumbing | 10 | 01-08-2010 03:41 PM |
