Old Cement Utility Sink - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
Old 01-24-2009, 11:26 AM   #16
the Musigician
DangerMouse's Avatar
pics worked fine, easier to see what you're having to deal with! if it was me, i'd grind away everything on the bottom with my angle grinder, then round out inside diameter and set in a new drain working from above. it'd have to be a hair smaller, but i shouldn't think it'd be a problem. silicone around the flange, of course. next step would be what? hooking 2 drains together, then to a trap and out? you said the trap is ok and permanent? what's that opening look like? pvc? steel?
DM
Old 01-24-2009, 01:10 PM   #17
Hi DM,
I'm not sure how I would set in a drain from above. See attached cross-view illustration of what I believe I have. There really is no room to go through either drain opening with non-bendable parts. The "built in" elbow (meaning it is part of the cement sink) at the drain is very shallow and narrow.
Any drain pipe parts would have to be attached from below.
Would this be feasible with epoxy and plenty of silicone?
I like the idea of the angle grinder! Thanks.
helpmyhusband is offline   Reply With Quote
Old 01-24-2009, 01:21 PM   #18
the Musigician
good drawing, i understand better now. how deep inside is it up the drain hole?
perhaps if you cleaned it out and glued/siliconed a flange to screw pipe to?
you'd most certainly want to flush it and clean it as best as possible with the grinder first.
a sanding wheel on a drill will clean up the inside for gluing.
DM
Old 01-24-2009, 01:42 PM   #19
ouch!
zosoplumber is offline   Reply With Quote
Old 05-13-2013, 03:17 PM   #20
Old utility sinks
I have an old cement utility sink as well, and my problem at the moment has to do with sewage. A month ago I can downstairs to my basement and smelled crap! I walked over to my utility sink and saw raw sewage and sewage water almost completely filling my sink. Intried plunging it, hoping it would go down, but no luck. I cant snake the drain because I have an old drain in it, and I don't know how to get it out, or if I even can get can't out! It's getting worse, because it's not going down. Do you, or anyone know how to remove old drains? If anyone can tell me how, I'd me much obliged, because I have the snake.
Jenel93 is offline   Reply With Quote
Old 05-13-2013, 03:18 PM   #21
Sorry for the typos.
Old 05-13-2013, 05:55 PM   #22
Plumber
TheEplumber's Avatar
Rewards Points: 792
The problem is probably not the sink- something downstream is causing the back up
Can you trace the outlet pipe and describe how it connects to the rest of the plumbing drains?
The Following User Says Thank You to TheEplumber For This Useful Post:
Nik333 (09-23-2016)
Old 05-13-2013, 06:05 PM   #23
Roofmaster
Rewards Points: 2,210
The best way to fix this is with a sledge hammer. Break the sink up into small pieces and take it to the landfill. Nothing but a PIA. Hire a plumber to install a new laundry tub with a proper trap. You do not want sewer gas in your house. Not trying to be rude, but this thing is way past its useful life.
SHR Plumber likes this.
The Following User Says Thank You to jagans For This Useful Post:
plumberinlaw (05-13-2013)
Old 05-13-2013, 06:37 PM   #24
Rewards Points: 2,032
I got a brilliant suggestion take a sludge hammer break it up into little pieces and go get a nice new fiberglass sink with legs.... Just saying....
http://www.homedepot.com/p/Swan-23-3...n#.UZF5bspbd6A
Hire a drain cleaner to open up your sewer...
The Following 5 Users Say Thank You to Ghostmaker For This Useful Post:
ben's plumbing (05-13-2013), Oso954 (09-23-2016), plumberinlaw (05-13-2013), SHR Plumber (09-24-2016), TheEplumber (05-13-2013)
Old 05-14-2013, 05:00 PM   #25
Unhappy
New User, slightly different direction
I have purchased an old single concrete tub for inside my newly constructed barn and have floor fed plumbing to attach. Does anyone have a suggestion where I might find a wall mounted/floor fed faucet? All the wall mounted faucets I have found either connect through the wall (not an option) or from above.
Ricky391 is offline   Reply With Quote
Old 05-14-2013, 06:05 PM   #26
http://www.plumbersurplus.com/Prod/C.../48300/Cat/526
Old 05-14-2013, 10:02 PM   #27
Doing it myself
Alan's Avatar
Rewards Points: 2,086
There may be another way to do it. . . . A diagram or a picture of what you're trying to do may help. (Also start a new topic, rather than interjecting into an old one)
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
Ricky391 (05-15-2013)
Old 09-22-2016, 03:06 PM   #28
Rewards Points: 730
Re: old cement utility sink
I know this is a very old thread, but I'm curious if the OP ever came up with a solution. I'm sort of in the same boat and my drain looks very similar. I have more on the bottom side, so I might be able to slide a metal drain pipe up and epoxy it into place and get mine to work. Of course the other current idea is to use it as an ice chest for the back patio.
Master Brian is offline   Reply With Quote
Old 09-23-2016, 03:44 PM   #29
Rewards Points: 1,646
I am amazed at the number of people who posted their own problems on this thread instead of starting their own.
bob22 is offline   Reply With Quote
Old 09-23-2016, 03:58 PM   #30
Oso954's Avatar
Rewards Points: 1,300
I guess they don't understand the reply
means it isn't worth the time or effort.
That phrase usually means the person has tried it or watched others try it, with unsatisfactory results.
Put a new sink in. If you want to repurpose it as a planter or a ice/beer container go ahead. Otherwise, break it up in little pieces.
Edit: not sure the ice chest is good idea. You are going to have a lot of thermal mass to cool down in addition to the beer, so it will take a lot more ice than just using an ice chest or even a plastic muck bucket.
Oso954 is online now   Reply With Quote
utility sink pump? mepeterser2451 Plumbing 3 12-01-2008 10:46 AM
Installing a utility sink BNPadgett Plumbing 1 05-03-2008 09:49 AM
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 09:11 PM
utility sink, washer drain simon Plumbing 4 11-14-2007 07:30 PM
Cement Utility Sink - Cracks and Leaks amazinlittledevil Plumbing 3 01-25-2007 02:59 PM
