Old Cement Laundry Tub - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-21-2010, 12:26 PM   #1
old cement laundry tub
I have an old two tub cement laundry tub and need to find a stand or some way to support.
bruabro is offline   Reply With Quote
Old 09-21-2010, 12:43 PM   #2
Rewards Points: 104
We did too, up until a few years ago. The best, easiest, and probably least expensive solution that I found (even if you figure your time at only $5 per hour) was a new fiberglass tub, which came with the legs.
Old 09-21-2010, 05:17 PM   #3
Rewards Points: 150
Those things are so old there's very little chance you will find a stand, the only thing you can do is make your own.
Like the other post said you would be better buying a new fiberglass tub.
braindead is offline   Reply With Quote
Old 09-21-2010, 09:22 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 676
Would you believe I carried one out of a basement today? Also a bunch of chunks of concrete. But the homeowners are tickled with their new plastic tub.
general question on portland cement rtoni Building & Construction 2 07-11-2009 08:32 AM
Rotten cement - skim coat or board? BradG Building & Construction 1 11-25-2007 02:25 PM
cement falling into basement from cement porch above. Betsy G Building & Construction 3 10-21-2007 12:53 PM
Cement Laundry Tub _ Paintable? Leenders Painting 2 02-18-2007 09:02 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
