Old Case 1000 Series Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-19-2012, 09:44 PM   #1
For Any of you that might be familiar with this toilet, was there a special way of plunging these units? or a special plunger?
When you try a standard plunger, it just seems to push water out of the inlet near the base. I can only plunge by using two plungers...one to cover the water inlet hole, and the other to do the actual plunging.
chuckman4112 is offline   Reply With Quote
Old 02-24-2012, 10:03 PM   #2
Bump...
Old 02-24-2012, 10:18 PM   #3
Can't say I'd ever seen one, but when plunging a sink with an overflow I use a rag to cover the overflow hole.
VIPlumber is offline   Reply With Quote
Old 02-25-2012, 06:25 PM   #4
Master Plumber
Javiles's Avatar
Rewards Points: 996
Ah the old briggs case.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 02-27-2012, 05:51 PM   #5
Yea that's what it is. She does not want to get rid of it, but using two plungers on it when it stuffs up is a bit hard on her as she has limited use of one hand. Just trying to see if there was a trick to plunging this thing.
Toilet issue: Shims, wax, general disarray. dawho1 Plumbing 8 01-23-2010 07:38 PM
Gurgling sound coming from the base of the toilet YerDugliness Plumbing 1 12-22-2009 08:35 AM
Toilet backfill after flushing hohadcr Plumbing 6 12-20-2009 04:01 PM
slow flushing toilet annoyances mcvane Plumbing 12 11-13-2008 03:00 PM
HELP - Seriously leaking toilet JAR Plumbing 3 11-03-2008 04:28 PM
